New Timing Belt - Defender Source
Old August 27th, 2006, 06:44 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
New Timing Belt
Hello, I just bought a 1994 Defender and the previous owner did not replace the timing belt. it has 69,000 miles on it and im worried its going to bust and mess everything up. what parts do i need, and where can i get them? also how much does it usually run for one of these to be replaced? I saw on here another thread with a $600 quote. sounds about right to me.
Daniel
Old August 27th, 2006, 11:20 PM
robisonservice
John Robison
2008 Supercharged Range Rover
V8 Land Rovers do not have timing belts. They use chains, which do not require service unless the engine has been neglected
Old August 27th, 2006, 11:31 PM
John, will you do the timing belt on a 300tdi? I'm at 35k on mine and will be moving to NY in a year or so.
Old August 27th, 2006, 11:38 PM
ini88's Avatar
ini88
Daniel Marcello
that is by far the best news i have ever heard!!! haha.
thanks so much. and yes you can laugh at such a newbie question!
Old October 13th, 2007, 12:26 PM
Flagg's Avatar
Flagg
Flagg
1995 Defender 90 NAS
HA!
I was worried about my timing belt. I was going through my records and realized it has never been replaced (like I have known to do on all other cars I have owned). I am an original owner - and feel like a fool for not knowing this!!!!!
This page is a wealth of knowledge - and easy to search things. Thanks everybody for making this page so awesome.
QUESTION: There has been a lot of talk about water pumps lately. I have about 89K miles on the truck. What has everyone had this done. With other cars I am used to doing this when the timing belt is replaced (cause they usually last longer but take the same labor to get to). It is a labor intensive to get to and change as a normal timing belt? Am I well overdue????
Thanks! Flagg.........
Old October 13th, 2007, 03:42 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
The water pump isn't too bad. If it is your first time I would set aside an entire saturday probably but it isn't really too bad. Easy work, just time consuming your first few times until you learn exactly which size each bolt is etc. As far as when to do it, I would say when it starts leaking or making noise, or if you have a lot of the ancilliaries off sometime and it is old.
Old October 14th, 2007, 02:36 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
The only real important things to do on the water pump are to make sure the gasket surfaces are really clean, and be very very careful that you keep the right bolts in the right spots. There are 14 bolts holding it on, with two different thread sizes and a bunch of different lengths.
My suggestion is get a piece of cardboard. Draw an outline of the water pump. Punch some holes where the bolts are, and stick them into the cardboard to keep them in order.
-Hans
My oil line fix
My 100k stopped odometer fix
Old October 15th, 2007, 07:42 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Jim, you shouldn't have to replace the belt for another 35k.........thats planning ahead ;-).
I generally do the water pump and the silly "P" gasket "while I'm in there" as well as a new serpentine tensioner bearing and flush of the intercooler.
Matt Browne
Old October 15th, 2007, 08:31 AM
Flagg's Avatar
Flagg
Flagg
Hans -
That sounds like a REALLY great sugestion with the cardboard.........thanks.
Flagg
Old October 15th, 2007, 09:46 AM
artm
Arthur Maravelis
97 SW
Originally Posted by junkyddog11
... and flush of the intercooler.
Matt, Anything in particular you use for the flush?
Old October 17th, 2007, 07:21 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
I remove the intercooler through the top of the rad frame and run it through the parts washer. I suppose that anything that will disolve oil including soapy water would work. Naturally all safety precautions and proper disposal practices should be strictly adhered to.
Matt Browne
300 TDI timing belt tensioner sundogcwolfe Defender Technical Discussions 7 December 15th, 2009 12:20 AM
300tdi timing belt change now problems discotdi Defender Technical Discussions 57 June 4th, 2009 10:10 PM
2.8 TGV Timing belt DesertRat Defender Technical Discussions 2 February 16th, 2009 07:12 AM
300 Tdi Timing Belt Question moose Defender Technical Discussions 11 January 22nd, 2008 03:58 PM
