New springs, why are there two different sizes? - Defender Source
Old March 13th, 2010, 10:35 PM
snowkistdynasty's Avatar
snowkistdynasty
Jared Stone
1984 Defender 110
Let me start by saying I sure you all know this so just enlighten me. I bought a lift kit from RoversNorth (genuine land rover springs) and two springs are taller than the others. WHY? And where do they go? Do I need spacers for that side and if I do, Why would they do that? I am new to defenders and just trying to replace thing as needed. I have a 110 and it sagged to the passenger side (RHD). I thought buying new springs would resolve that and I wanted to go a touch higher. I just would like to understand why? Any help would be appreciated.
Old March 13th, 2010, 10:45 PM
bjf's Avatar
bjf
barry f
94 ST #395
Springs are side specific. I wonder though if you should reverse the sides as I thought they set them up based on a left hand driver always in the truck.
Old March 13th, 2010, 11:03 PM
Lucasd2002's Avatar
Lucasd2002
David Lucas
[VACANT]
OME does this also. However, if you buy your OME springs from Expedition Exchange, they match springs and send them to you so the springs for each side are the same. Maybe RN will take those back?
Old March 14th, 2010, 04:22 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
The taller springs go on the RH side.
Saying that though I have he same length springs on my 110 - 90 rears on the front & 130 outers on the rear = heavy duty 1 tonne spec.
Mike Hammond
Old March 14th, 2010, 07:11 AM
pushngo
Randy Williams
Is he not talking front to back?
The heavier longer tighter wound springs go to the rear. I was not aware that L/R had handed springs and as said before I would recommend an aftermarket spring Call Justin at Lucky 8
Old March 14th, 2010, 10:26 AM
bitz's Avatar
bitz
Jon
NAS D90, 85 D110 CSW, 66 Dormobile
My Genuine HD springs were the same way. I looked up the part number for each and made sure they went on the correct side. It looks fine after install.
Old March 14th, 2010, 10:31 AM
I have OME 2" springs that are handed like that. I put the tall one on one side in the back and the other side in the front. The truck sits level if just a little low in the front after a year or so.
Old March 14th, 2010, 02:07 PM
mikeslandrover
Mike Hammond
110 rear springs are a larger diameter than the front springs.
Mike Hammond
Old March 14th, 2010, 02:28 PM
Rugbier's Avatar
Rugbier
Gustavo
I wonder how a 110 will run with OME for 130?
Anyone done this? what OME spring was used?
NO SIGNATURE
Old March 15th, 2010, 08:39 AM
you mean OEM?
per rimmer bros.
130 up to VIN WA159806 (1998)
1 OE*ROAD SPRING DRIVERS SIDE HD 110 - Part No. NRC9448
1 OE*ROAD SPRING PASSENGERS SIDE HD 110 - Part No. NRC9449
1 OE*REAR ROAD SPRING DRIVERS SIDE 110/130 - Part No. NRC6389
1 OR*REAR ROAD SPRING PASSENGERS SIDE 110 /130 - Part No. NRC6904
130 VIN XA159807 (1999) on
2 OE*ROAD SPRING 110/130 XA 159807 ON - Part No. RKB101111
Old March 15th, 2010, 08:55 AM
Rugbier's Avatar
Rugbier
Gustavo
Dave,
Thanks for those numbers.
Actually Iwas wondering for Old Man Emu
NO SIGNATURE
Old March 16th, 2010, 01:17 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Here is a fun Link for you. Land Rover and most of the aftermarket spring suppliers provide slightly longer springs to be used on the driver's side of the vehicle, presumably because the vehicle will often times be occupied by only one person (hopefully the driver)? Or is it because the heavy A** battery sits under the driver's butt? I dunno the real thinking behind it, but I know its true..
Many Vendors will (like EE and Great Basin) take apart the spring sets and sell you matched heights (either the slightly shorter or slightly longer ones) since I don't think anyone really subscribes to the 'need' to stagger the lengths like this..
~Scott T.
'95 D-90 ST - AA Yellow
Old March 16th, 2010, 11:44 PM
snowkistdynasty
Jared Stone
1984 Defender 110
got it sorted, thanks for all your help.
Old March 17th, 2010, 08:19 AM
What was the end result?
Old March 17th, 2010, 02:49 PM
snowkistdynasty
Jared Stone
1984 Defender 110
I put the taller springs on my passenger side(RHD). It came out level. So that is all I was looking for. Thanks again.
SG winch bumper, GKN torque limiters, OME 751 springs Shane@EVS For Sale - Parts 24 June 1st, 2006 02:37 PM
D90 Springs... arbik Wanted 2 March 25th, 2006 10:09 AM
Stock height aftermarket springs? lmaldonado Defender Technical Discussions 3 June 29th, 2005 08:23 AM
new springs? scoloco Defender Technical Discussions 4 April 5th, 2004 06:08 PM
OME springs! TwisteD90 Misc. Chit-Chat 5 October 2nd, 2003 06:16 PM
