new springs? - Defender Source
Old January 14th, 2004, 06:07 PM
scoloco's Avatar
scoloco
'94 D90 ST
new springs?
I'm looking to put new OME springs under my D90.
My original thought was 751/762 combo, but I've seen enough comments to wonder if a better config is available. Some folks run 762 or 764 all round.
I plan to put 285s under it soon. This will for all intents and purposes be a daily driver, and trail machine. So I'm looking for something all round, and not totally dedicated to the trail. Perhaps an inch or two of lift would be nice.
Currently I have stock springs and Rancho9000 shocks. '94 softtop with a winch up front.
Based on the above, any recommendations on which OME springs (and do I need to swap out my shocks, if so to what) I should consider. And why.
tnx for any input.
-scott
Old January 14th, 2004, 08:16 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Call John Lee at the www.expeditionexchange.com or check out the site. they have alot of info on the springs
Legend in My Own Mind.
Old January 14th, 2004, 08:35 PM
ronward's Avatar
ronward
Redsrover
None - sadly
Scott, I have 751 HD front and 764 MD rear on my 1997 90 soft top with ARB bumber and winch up front. Truck sits just slightly lower in front by a half inch or so when the rear is empty. When fully loaded, she sits a bit low in the back. If I had it to do all over again I'd go with the 751 heavy duty in front and the 762 heavy duty in the rear for a more balanced look when loaded for camping/wheeling trips. My $0.02 worth.
Oh, and I run ARB shocks and got the whole suspension setup from John at EE. I have 255 85 16 BFG MT's.
Old January 20th, 2004, 10:03 AM
scoloco's Avatar
scoloco
'94 D90 ST
Ron,
when your truck is fully loaded, how much stuff you got? What sorts of things? (Trying to figure out how often I'll be going that heavy)
-scott
Old April 5th, 2004, 06:08 PM
ronward's Avatar
ronward
Redsrover
None - sadly
Sorry, I forgot about this post for a while... When fully loaded I run about 250 - 300 lbs of gear and I remove the rear forward facing seat and brackets.
SG winch bumper, GKN torque limiters, OME 751 springs Shane@EVS For Sale - Parts 24 June 1st, 2006 02:37 PM
D90 Springs... arbik Wanted 2 March 25th, 2006 10:09 AM
Stock height aftermarket springs? lmaldonado Defender Technical Discussions 3 June 29th, 2005 08:23 AM
OME springs: "A" and "B"?? jaherring Defender Technical Discussions 3 October 30th, 2004 05:49 AM
OME springs! TwisteD90 Misc. Chit-Chat 5 October 2nd, 2003 06:16 PM
