New Speedo Install Help - Defender Source
Old March 26th, 2009, 07:53 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
I'm currently converting to electronic speedo on the D90 and still waiting for the Transducer to arrive, but I could not wait to see it on at night.
I wired interior light power to pins# +4 & -7 but nothing happens, can anyone point out what I'm doing wrong?
Here is a pin layout fot the speedo:
Old March 26th, 2009, 08:57 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Black is your ground. Take a voltmeter and figure out which of the others is giving you a 12v source with the lights. It may be a fuse or some other issue, but the voltmeter should help to sort the issue. On my instruments I have a commorn source suppling the necessary 12v to all the instruments - not just the speedometer. Are the other guages lighting up?
Old March 26th, 2009, 08:58 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
yes, all others are lit with the same power source for night time lighting.
but you are correct let me put the trusty voltmeter to check the input pins into the speedo head.
Old March 26th, 2009, 09:04 AM
cabell's Avatar
cabell
Cabell Crowther
The electronic speedo illumination is in series with the other guage illumination. Red / orange I think, possibly red white on your truck. Check your ground(s), there are several coming into the guage area. Do you have the td5 binnacle wiring loom? It makes things much easier. If you bought the speedo used you could have bad bulbs ( I did). Get the bulbs from your local BMW stealership ($5), as RN charges $27 ea.
Old March 26th, 2009, 09:23 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
I do have the TD5 wiring loom & just tied into it, very easy....I will check tonight for voltage at the pins...The bulbs are a good suggestion to check
Old March 26th, 2009, 10:02 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I don't know how the gauge is wired internally, but it is possible that you need to have either the constant 12v or ignition connected. I would start by connecting the constant 12v and seeing if it works, then go from there.
Old March 26th, 2009, 10:39 AM
cabell's Avatar
cabell
Cabell Crowther
That is true Andrew, but I think the permanent feed is to keep the odometer reading only and shouldn't affect bulbs that handle the guage lighting.
Old March 26th, 2009, 10:41 AM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
I did not think about connecting the constant source, but a great idea...eventually it would need connecting anyway.
Old March 26th, 2009, 10:48 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Well, my thinking is that VDO may use the constant to power the bulbs, and just use the illum. lead to trigger a relay or something similar inside. Sort of like how radio's don't get their power from the ignition lead, but from the constant and the ign. lead just tells it when to turn on.
speedo
VDO SPeedo roverboy Defender Technical Discussions 69 March 1st, 2015 10:35 AM
4.6 install will it work ron Defender Technical Discussions 16 February 7th, 2008 10:16 AM
speedo cable scoloco Defender Technical Discussions 7 November 3rd, 2005 07:54 AM
Hitch/ pull point install question JKM Defender Technical Discussions 3 May 18th, 2004 08:39 AM
VDO speedo for sale vlocci For Sale - Parts 3 May 2nd, 2004 12:38 PM
