New speedo dialed up? - Defender Source
Old January 7th, 2013, 08:03 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Is it possible to dial up a new factory speedo? For instance, if my truck has xxx,xxx amount of miles, but the odo breaks, can I replace and dial it up to correct mileage?
http://landroverparts.roversnorth.co...x?code=PRC7373
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old January 7th, 2013, 08:14 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
Sure, call a local speedo shop and they can do it. I have used North Hollywood Speedo and been pleased. $75 to set a defender odometer last I spoke to them.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old January 8th, 2013, 12:07 PM
GYM's Avatar
GYM
Gary
97 SW
Was the unit you sent for a 97 or an earlier mechanical version? What was turnaround time?
Thx
Old January 8th, 2013, 01:50 PM
Reese_D90's Avatar
Reese_D90
Reese
I have sent both digital and mechanical.
I think they turned them around in a week or so
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old January 8th, 2013, 01:51 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Thanks for the info, I think I may just need my odo part rebuilt as the speedo works, just not the odo. I will give them a ring!
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old January 8th, 2013, 02:08 PM
Reese_D90's Avatar
Reese_D90
Reese
If you are now talking about the required fix for a broken 97 odometer, that's a whole new conversation. Search it as there is plenty of posts on it. Last I heard NHS was making that repair.
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Mine is a 94 model, analog odo...
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old January 8th, 2013, 02:29 PM
If it stuck at 100k, you can open it up and turn it over to work again.
Old January 8th, 2013, 02:45 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
Thanks for the info, do you mean just open up and try and turn or dial it up manually? This should correct the odo and make it run again?
1994 Defender 90
2006 LR3 SE
2006 LR3 SE (sold)
Old January 8th, 2013, 02:58 PM
Yes.
This was done (not by me) on one I owed. I am not sure how exactly as I have not done it, but the PO said it was just pry open and roll forward.
Old January 8th, 2013, 10:13 PM
Yes.
You have to remove the black bezel .... Pry it off gently with a screw driver... It goes back on but takes a bit of tweaking.
speedo
VDO SPeedo roverboy Defender Technical Discussions 69 March 1st, 2015 10:35 AM
speedo cable scoloco Defender Technical Discussions 7 November 3rd, 2005 07:54 AM
VDO speedo for sale vlocci For Sale - Parts 3 May 2nd, 2004 12:38 PM
Speedo correction d90Monkey Defender Technical Discussions 2 April 21st, 2004 12:05 PM
Speedo Transducer???? Eric Siepmann Defender Technical Discussions 1 December 19th, 2003 05:50 PM
