New soft top header bar issue...help? - Defender Source
Old November 23rd, 2013, 11:43 AM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
I'm switching out the windscreen connection (header bar?) for my new soft top. The old MOD style which had spring loaded cams/clamps and accepted the cylindrical soft top leading edge was removed (and donated to Javelinadave!) and in turn he sent me his header bar that accepts the soft tops with the flat leading edge
I thought it would be a easy swap, but I'm perhaps missing something obvious. The mounting holes line up, but the way the bar sits on the top of the windscreen is about 1/2 inch too far forward. Problem is I cannot move it back because of the gutter kit.
It *appears that the way around this, to move the bar back a 1/2" so the holes line up, is to notch out the header bar with a cut off wheel etc allowing room for the header bar to sit flush and in the correct place.
But I can't be the first person to do this and don't want to miss something obvious. Rather not hack something up if I don't need to.
Mucho thanks in advance.
Josh
ID:	84830   Click image for larger version
Old November 24th, 2013, 07:44 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
The header bar goes under the gutter kit. Mine was a really tight fit, you really have to jam the gutter kit into the grove behind the section that the soft top slips into. That said, I can't tell from the pics if you have the same gutter kit as me, but that is the header bar I used
Old November 24th, 2013, 11:39 AM
josh-man's Avatar
josh-man
joshua
Few more pics. Not sure if that's the case with this one.
Much appreciated
ID:	84867   Click image for larger version
Old November 24th, 2013, 12:08 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
I just took off my header bar and gutter kit. Here are some Picts that might be helpful
ID:	84870   Click image for larger version
Old November 24th, 2013, 12:12 PM
josh-man's Avatar
josh-man
joshua
Thx. So yours goes on top of the gutter kit. Wonder if the MOD gutter kit is different than the ROW's?
Old November 24th, 2013, 12:22 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
Yeah it goes on top
Here is a link scroll down to bottom for another pic and the different styles of header bars
http://www.allwheeltrim.co.uk/Frames.html#S1
Old November 24th, 2013, 01:42 PM
josh-man's Avatar
josh-man
joshua
Yeah it goes on top Here is a link scroll down to bottom for another pic and the different styles of header bars http://www.allwheeltrim.co.uk/Frames.html#S1
Ahhhhh. I may just have one compatible with the ROW set ups. Oh well. Made it work!
Few minutes with a cut off tool and a tube of silicone.....
Thx for the help boys.
Old November 25th, 2013, 12:31 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Nice to see you got it sorted
legend in my own mind
Looking for "bar" on top of windscreen for soft top chuckc4 For Sale - Parts 2 March 8th, 2006 12:56 PM
95 Beluga Black D-90 Soft Top... obie For Sale - Vehicles 12 January 29th, 2006 09:46 AM
for sale 95 soft top W/ fiberglass hardtop jonjon For Sale - Vehicles 2 March 24th, 2005 07:19 PM
Have a trashed Bestop soft top? Need tailgate clips, vertical rails, misc. jaherring Wanted 3 September 24th, 2004 09:15 PM
Which is the best soft top for D-90? bbandit Defender Technical Discussions 13 March 9th, 2004 08:40 PM
