New Shock Absorber advice - Defender Source
Old August 27th, 2007, 10:47 AM
ecmgbob
Robert (Bob) Mills
97 D-90 SW
All:
I have a 97 Defender 90 SW with about 87K on the Odometer. Doing the basic shake side to side test yields what I sense to be excess play or give in the shocks in that the vehicle will continue to move side to side 2-3 times prior to coming to a complete rest. The rebound test (pushing down on the bumpers) yields the same result.
Is it time to replace the stock shocks? and if so, what OE or aftermarket set up most closely matches the stock set up? I envision light to moderate off roading in Missouri and North West Arkansas and do not see the need to lift it so as to be able to rock crawl or anything like that.
I am sure this will stir up a lot of opinions and maybe some controversy as to the optimal set up.
Thanks in advance for all of your help.
Old August 27th, 2007, 11:22 AM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
Most people that are just replacing their stock shocks with something comprable seem to go with Old Man Emu or Bilstein shocks in the stock length. They can be had from all the vendors for around the same price.
Shock Absorber Poll Weldon Defender Technical Discussions 11 May 30th, 2009 10:46 AM
Pics of modded shock towers??? cbass Defender Technical Discussions 27 November 21st, 2008 08:52 PM
Shock Install Advice Grover Defender Technical Discussions 11 September 9th, 2006 09:42 PM
Shock advice? roverboy Defender Technical Discussions 8 February 19th, 2004 06:11 PM
Rancho 9005 shock DBZ2009 Defender Technical Discussions 6 December 13th, 2003 10:28 AM
