New Rubber Suspension Bushings - Defender Source
Old August 3rd, 2006, 01:45 PM
redrockrover's Avatar
redrockrover
Russell Phillips
1994 Defender 90
Who and where do you recommend for all new rubber suspension bushings. I am going to remove my old crumbling rubber bushings and replace with new ones. I know rovers north has them any place less expensive that comes to mind? I want to tighten up my handling on road. Thanks!
Russ
'94 AA Yellow
# 891
Old August 3rd, 2006, 02:00 PM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
I replaced mine with a polybush kit not as cheap as std landrover replacement items but well worth it, Road handling is much much better and they last longer than the metalized rubber bushes do
Old August 3rd, 2006, 03:01 PM
From what I have heard the poly bushings don't hold up well if you offroad, they don't like flexing nearly as much as the stock rubber bushings.
I would guess RDS or DAP would have the best prices on rubber bushings.
http://www.roversdownsouth.com/
http://www.dap-inc.com/homeframe.htm
Old August 3rd, 2006, 03:53 PM
redrockrover
Russell Phillips
1994 Defender 90
Thanks, I really want to keep the rubber because I want the flex off-road. I use the d-90 in the dirt and the street alot. I think the rubber offers the best of both worlds. Thanks
Thanks Matt,
Just ordered a kit from DAP. Thanks again
Russ
Russ
'94 AA Yellow
# 891
Old August 3rd, 2006, 10:16 PM
I have the orange poly bushes that RN sells and I think they are too hard. I will replace them with rubber when I get a chance.
Old August 4th, 2006, 03:51 AM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
Personal preference I guess, but then again my 90 is heavy with the winch bumper and diesel engine plus all the kit I carry. The rubber bushes didn't last five minutes particularly the front radius arm bushes
Old August 4th, 2006, 08:14 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Outside of the UK, I haven't heard one good thing about poly...
Old August 4th, 2006, 08:35 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Do you know anyone that has the original Polybush bushings in orange?
John C.
Old September 8th, 2006, 12:35 PM
48vphantom's Avatar
48vphantom
Jeff Hoien
1997 NAS D90
I see DAP has two versions of the rubber bush kits with and without hardware. Anyone have a say which one is the best choice...
thanks
jeff
Old September 8th, 2006, 12:41 PM
GeoParth's Avatar
GeoParth
George Parthmer
1995/d-90 #2715 yellowST
my ome suspension bushings are CRAP. i keep losing them. wtf?
Old September 8th, 2006, 12:56 PM
Matt Taylor
Matt Taylor
Maybe you're torquing the nuts too tight? Are you squishing the bushings?
Old September 8th, 2006, 01:07 PM
JohnC
What kinda shocks you using? If you have the longer shocks I believe those are made for a LC and not a LR. At leasts that's what I heard.
John C.
Old September 8th, 2006, 02:55 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
The rubber bushings that look all shiny and painted don't last, the ones that look rough and crappy right out the box last a long time.
bushings, rubber
WHY WHY WHY am I blowing through suspension bushings? KevinNY Defender Technical Discussions 27 September 13th, 2007 02:29 PM
Rear trailing arm bushing failure sheki Defender Technical Discussions 23 July 5th, 2006 09:20 PM
Body bushings - poly or factor rubber?? jaherring Defender Technical Discussions 15 February 10th, 2005 06:42 PM
Front End Wobble RyanS Defender Technical Discussions 7 April 13th, 2004 05:21 PM
Rear Suspension Question dnewman9 Defender Technical Discussions 3 February 1st, 2004 06:31 PM
