new rear axle - Defender Source
Old January 24th, 2005, 01:21 PM
rolaro
Jan-Dirk Roodbol
1985
new rear axle
After replacing the 3.5 ltr. V8 to 4.6 ltr., it is now time to modify the brake system.
Front to vented disk brakes is not a problem, more the rear.
The 110 , 1985 rear axle is a Salisbury with drum brakes.
I want a complete axle swap, but want to keep the "Salisbury strength".
The early RRC's have 10 splines, but the later ones have the stonger 24 splines/ diffs.
Do you know guys which year/type Range Rover or maybe Discovery axle I can choose, or do you have an other solution?
cheers
Old January 24th, 2005, 01:43 PM
whistler110's Avatar
whistler110
Mike Johnstone
ex-mod 110
Just get a newer Salisbury out of a 110, they switched to discs around 94/95 and are 24 spline. It's a direct swap.
Bike Mike
Old January 25th, 2005, 08:42 AM
rolaro
Jan-Dirk Roodbol
1985
Thank you for your reply Wistler 110,
I knew that the later 110 300 TDi and the early TD5 used them , but only for a while, and and very hard to find in Holland. That's why I was looking for an alternative.
Is a Rover axle with an upgrade 4-pin diff and 24 splines shaft ( ashcroft ) the best solution?
cheers
Old January 25th, 2005, 11:58 AM
It won't be a bolt in. You'll need a longer propshaft. The spring mounts will need to be changed over. The R&P will still be a weak point. A lot of work to give a weaker axle for the goal of changing to disc brakes.
Why do you want discs so badly?
Old January 26th, 2005, 01:01 AM
JSQ's Avatar
JSQ
Jack Quinlan
keep the sals and mount RRC front calipers to it with discs.
Old January 26th, 2005, 07:16 AM
rolaro
Jan-Dirk Roodbol
1985
Thanks for the reply Red 90 , JSQ
I need the discs, because brake system of the 110 was enginered for a 3,5 ltr. engine, now a have a 4,6 ltr injection which runs like Speedy Gonzales, okay you may say handle the gas trottle with care.....
What JSQ suggests is not possible, the shafts won't fit.
A weld-on system is also no option, this because of strick regulations in Holland.
That's why I was thinking of a Rover axle with upgraded diff/shafts.
We all know that the Salisbury axle is the strongest one which Land Rover has, or better said had.
But what makes the Salisbury stonger/better, compared with the standard Rover axle?
maybe you guys will have a solution for me.
cheers.
Old January 26th, 2005, 07:52 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Jan, contact www.equicar.co.uk They will have what you are looking for.
Legend in My Own Mind.
Old January 26th, 2005, 10:15 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
The rear drum system stops the truck remarkably well. I have 37's and rear drums, sure there a bitch when it comes time to tinker with them but you will not notice any significant gain by changing to disks. Keep in mind that an average car relies 60% on the front brakes. In trucks like ours I would guess it is closer to 65-70% Get some vented rotors and upgraded pads for the front and call it a day. As to your other question, the sals has an uber beefy r+p, but other than that, it is as weak as any other Rover axle.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 26th, 2005, 11:34 AM
As stated, rear discs won't increase braking ability. The drums braking ability is as good as the discs. The only real advantage to discs is they don't wear as quickly if used in a lot of mud. Make sure the drums are adjusted properly. They are manually adjusted as apposed to most cars which have auto adjusters.
Most braking in any vehicle comes from the front brakes. The later style vented front brakes are better. You can switch to these buy changing calipers or adding a specer in the caliper body.
As to strength. The Salisbury axle uses a 4 pinion Dana 60 center with a Dana 60 R&P. Basically unbreakable is any Rover application. The halfshafts are standard Rover 24 spline though and are not that strong. It is possible to change to Dana 30 or 35 spline which then makes it strong enough for anything.
This is a picture of a 4 pinion Rover diff next to a Salisbury diff.
http://www.4wdworld.com.au/products/...rive_part1.jpg
axle
1997 Defender 90 Rear Axle Casing Steve Friedman Wanted 3 March 8th, 2009 07:33 PM
Complete HD Salisbury Rear Axle For Sale Northface For Sale - Parts 4 July 21st, 2006 08:29 PM
Disco Axle, Tire Cover, D-90 top, D-90 rear seat, Safari Gard Bumper m016324 For Sale - Parts 17 January 4th, 2006 09:20 AM
24 Spline Axle Shaft (Long Side) + CV Joint + Rear Housing mudrover For Sale - Parts 0 March 2nd, 2005 09:48 AM
