new leak - Defender Source
Old December 21st, 2003, 08:45 PM
Unhappy new leak
well not really new but has reappeared. on my rear diff at the yoke/front of the diff where the drive shaft goes in it appears to be leaking. How big a deal is this if its leaking? I keep the fluid full doesnt leak that much but you can tell its losing fluid. The way Is this a hard seal to fix? I am not really sure about the rover diffs? would the 3rd member have to come out to fix it? I had it in the shop the ohter day they didnt seem to notice.........
Old December 22nd, 2003, 08:56 AM
I don't think you have to pull the 3rd member. You just remove the Drive-shaft then undo the pinion nut and I think the seal is under that. Someone asked this not too long ago and it was a relatively simple fix.
Old December 22nd, 2003, 12:06 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
I asked this question under the heading differential about a week ago and got a response on fixing the problem. But this is what I have done so far. My leak is very small to the point where there is just now getting a small drop on the garage floor. I noticed the flange looked like it was bent or coming out a little bit at the bottom where the leak was. I took a peice of wood and tapped it with a hammer so the flange is now even all the way around. There was no drops on the floor this morning but it will take a few days fo driving to see if I actually did anything.
Old December 22nd, 2003, 11:26 PM
jorge's Avatar
jorge
JORGE ESPINOZA
97 ST WHITE MODS SUPERCHARGED
I just had my U/J changed,as the drive shaft was being reinstalled my mechanic (quick plug)Vinny, Import specialist, noticed a drop of fluid and proceeded to reseat the seal and the leak stopped.The job is not complicated and just took a minute.
Old December 22nd, 2003, 11:42 PM
thanks i will take a look tomorrow and see.
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Oil Pan Leak Eric Siepmann Defender Technical Discussions 11 May 25th, 2005 09:47 AM
New Leak d901560 Defender Technical Discussions 0 May 2nd, 2005 03:21 PM
ATF Leak. What could it be? mdmccallum Defender Technical Discussions 2 September 22nd, 2004 09:08 PM
Exhaust leak dmarchand Defender Technical Discussions 12 February 4th, 2004 03:12 PM
