New Leak - Defender Source
Old May 2nd, 2005, 03:21 PM
d901560's Avatar
d901560
Brian B
94 ST
New Leak
I couple weeks ago I noticed a new leak in the driveway. It is brake fluid and it's coming from the brake master cylinder. There is no fluid on the inside of the firewall or next to where the brake cylinder is bolted to the servo. It appears to be leaking from the bottom of the reservoir. The leak is very intermittent and my fluid level is a little below the top full mark so I doubt it is overflowing out the top. I'm thinking it may be a bad seal between the reservoir and the cylinder. Has anybody replaced just the reservoir? I searched and didn't find any other posts about this.
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Oil Pan Leak Eric Siepmann Defender Technical Discussions 11 May 25th, 2005 09:47 AM
Vacuum Leak Eric Siepmann Defender Technical Discussions 2 November 25th, 2004 09:11 PM
ATF Leak. What could it be? mdmccallum Defender Technical Discussions 2 September 22nd, 2004 09:08 PM
Exhaust leak dmarchand Defender Technical Discussions 12 February 4th, 2004 03:12 PM
