new head and injectors, now more black smoke - Defender Source
Old September 6th, 2015, 11:12 AM
USLandy's Avatar
USLandy
Andrew
defender 90
Couple weeks back I stripped off my old head on my 300tdi and replaced it with a new high flow turner head, replaced the injectors and glow plugs too. After running it for a few weeks I've had a noticeable increase in black smoke and also my EGT has increased. EGT used to be between 850-950 general highway cruising speed. Now on hard acceleration up a hill at 60mph ill be closer to 1150-1250 then i'll let off the skinny pedal as not to get it too hot. I know that it can get up to 1300 but it used to run cooler. I'm wondering that the old injectors were nicely covered in carbon build up, with the new injectors maybe they are injecting how they were supposed to so its putting more fuel into the pistons?? Anyone had similar thing after replacing injectors, maybe think it could be as I think? Should I turn down the fuel a tad??
On a side note, I have not messed with the fuel ratio, the engine was bought used so someone may have tweaked it before I got it. I do live up in Colorado so there is less air up by me, the lower oxygen decreasing the combustion efficiency may have something to do with it too.
Thanks in advance !
ac
200tdi massive black smoke on .. Rugbier Defender Technical Discussions 36 May 1st, 2017 07:54 AM
Boom, Smoke and head scratching Rover110 Defender Technical Discussions 15 June 28th, 2013 12:07 PM
300TDI Black Smoke on startup drv2fst Defender Technical Discussions 27 July 15th, 2010 04:53 PM
So now that Dash Bezel is NLA, what are we to do now? Neil McCauley Misc. Chit-Chat 7 October 9th, 2009 07:51 PM
Puffs of black smoke devinchi Defender Technical Discussions 10 December 31st, 2008 09:05 AM
