New Guy w/Brake Issue... - Defender Source
Old May 12th, 2011, 05:59 PM
emmodg
J.B.
1984 110
The '85 110 we have is leaking brake fluid out of the brake pressure warning sender at the bottom of the brake pressure relief valve which is bolted to the firewall under the clutch MC. I replaced the pressure warning sender as I thought it was the problem but now the new one seems to be leaking enough to make the pedal go to the floor. I thought this sender was bolted to a brake manifold but I guess it's actually got some kind of a bias valve in it. Could it be getting stuck and allowing pressure to force fluid out of the pressure warning sender "thingy"? All of the brake lines are dry. Does the truck need this manifold/pressure valve? Could I run a bias valve instead?
Thanks!
Old May 12th, 2011, 06:28 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Is it drums or disks in the back?
And does it have a bike rack for the ten speed...
Old May 12th, 2011, 06:32 PM
emmodg
J.B.
1984 110
Drums in the back. I took the rack off.
Old May 12th, 2011, 06:36 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Bias valve would work, but I'm sure others will chime in...any plans to put disks on the rear? If so, a proportioning valve from a d1 would work in that case.
Old May 12th, 2011, 06:54 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
2nd the D1 valve. It would be considered an upgrade too!
Old May 12th, 2011, 08:30 PM
emmodg
J.B.
1984 110
No plans to put discs on the back. I was wondering if I could get a bias valve... I'll look for some. Any recommendations for where to find one? Summit? Jegs?
------ Follow up post added May 12th, 2011 06:51 PM ------
I found some bias/proportioning valves on Summit Racing. They all have either single inlet/single outlet or dual inlet/three outlet. I guess I could block off an outlet?
brake
Clutch issue? Help with diagnosis..... Hans Defender Technical Discussions 13 December 18th, 2005 05:19 PM
What is this guy thinking? boshea Misc. Chit-Chat 12 October 11th, 2005 03:18 PM
strange heat issue jabber Defender Technical Discussions 15 March 6th, 2005 05:42 PM
blue sky montana rover guy 94d90 Misc. Chit-Chat 2 November 14th, 2003 10:59 PM
