New Guy - Old Problem - Page 4 - Defender Source
Old October 10th, 2011, 02:03 AM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
Originally Posted by chris snell View Post
That wasn't me. I've only been here a little over a year.
I live down on Cheyenne Mountain and I'm usually driving my truck to downtown for lunch or whatever. No three-link, it looks like this: http://www.flickr.com/photos/defende...57625240335210
Is yours the green SW with the South African flag that I've seen around?
Negative. This is me. I'm in Cheyenne Caņon.
Old December 1st, 2011, 03:27 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
UPDATE: Some problems solved, other problems generated. I SO wish I had left my springs stock!
Installed GBR DC shaft (front) and 4.11 True Track diffs in front and rear.
Turns out, the neutral float grunt was the rear shaft (damn). I verified that by trucking around for a few days with just the new front shaft. $400 down the pisser. Still, I'm happy to have it over stock.
Now for something funny... (and by "funny" I mean really f'n disconcerting) my TrueTrack diffs LOCK (and I do mean 100% locked) when the T-case is locked (high or low) - axles moaning/pinging on pavement, tires skipping... the works. Weird, eh? I put the T-case in normal mode and I can turn tight circles on pavement again. Even Bill Davis is perplexed. Any of you ever hear of a limited slip diff locking?
Old July 30th, 2012, 04:16 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
Just a quick update - just shy of 1 year later... and I am finally on my way to resolution. The miserable TrueTrac in the rear of my 97 D90 is coming out soon. It will be replaced with an ARB. The TrueTrac in the front has been silent since day 1. I'm leaving it there. If it causes any issues with steering this winter (on snow or ice), it will get replaced with an ARB immediately. Some people say it will, some people say it won't. I will know one way or another in due course.
The rest of this post is primarily directed at anyone who is new to this discussion (like I was) and needs some answers. Learn from my mistakes!
There is SO much good advise in this thread and I wish I had the ability to go back in time knowing what I know now. My current knowledge on this subject makes previous suggestions so clear - so easy to understand. At the time I started this thread, however, I just didn't get it. Boy do I get it now.
I have spend hundreds of hours and thousands of dollars chasing what could have been resolved with a properly built DC rear shaft and adjustable rear training arms (my truck needed both). BOTH of the suggestions to do that were pointed out in post #2 and post #4 of this thread. If I really wanted to knock it out of the park, I could have bought the OEM 3rds for $500 and been stoked.
The upside has been the 4.11 gears. They really do work well for me in the foothills of Colorado. But... my speedo is way off now. Had I known... ugh.
If you find yourself reading this thread while getting ready to lift your D90 SW or you're here trying to figure out how to fix the same issues, I offer you the following opinions:
1) Stay away from TrueTracs in your Defender unless you are okay with a great deal of ratcheting and clunking noises. I have heard some people say their truck is quiet and others who have a great deal of noise (like me). In fact, the TT in the front of my truck has been quiet since day one but the rear has had significant issues - some related (in my opinion) to the set up and some (in my opinion) to the nature of the TT design and the design of the D90 drive-train.
2) Daily drivers should seriously consider ARB lockers because they're open diffs unless you lock them when they need to be locked. If you think the extra few hundred bucks for ARB diffs isn't worth it, consider the value of your sanity. If you want a quiet drive train around corners and backing out of parking spots, skip the TT's.
3) I am hearing (from some reputable vendors) that about 50% of D90 station wagons that get lifted 2" or less work just fine and that the other 50% need adjustable training arms, a DC rear shaft, or both to resolve the pinion angle problem. In my case, both were required. Plan in it and you won't be caught off guard.
Finally, I suggest you listen to the people on this board, if you don't understand, don't be afraid to look like an idiot by asking the same questions until you do - or you may look like a much bigger idiot for failing to take some very good advise.
Ask me how I know.
Onward.
Old July 30th, 2012, 04:45 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Was there any recourse with your rear truetrac from the vendor?
Old July 30th, 2012, 06:02 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
Yes. I'm not saying it was pretty, but we're both moving forward.
I'm focused on locating, buying, and installing a new ARB rear diff with 4.11 gears and getting this whole conversation firmly behind me - forever.
Help! Problem starting (95 SW) reaper99999 Defender Technical Discussions 8 March 2nd, 2006 07:22 PM
Wobbly distributor cap? and an update on my starter problem MiniGuy Defender Technical Discussions 6 January 10th, 2006 10:13 AM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
blue sky montana rover guy 94d90 Misc. Chit-Chat 2 November 14th, 2003 10:59 PM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
