new gears speedo way off - Defender Source
Old June 14th, 2010, 07:05 PM
BLUE94's Avatar
BLUE94
Kelby Saxton
1994 Defender 90
Is there a simple way to correct the speed variation on a 94? I recently had 4.14 gears installed and went to a 285 tire and my speedo is around 17 mph. off at higher speeds and with the speed governer I am only able to go about 72 mph. I have heard that you can do a pick up off a 97 or a disco and use a VDO speedo, but I would really like to stay with the factory speedo.
Old June 14th, 2010, 07:27 PM
Two options... Put 35's on or install a VDO speedo, where you can calibrate the speedo to your gears/tires.
Old June 14th, 2010, 09:32 PM
WhiteD90's Avatar
WhiteD90
Johnathan Tisdale
93 110, 90 RockRR buggy
looks like you have a 94, you can try this cheaply to see if it helps. I did this in my 90 and it worked well. use the search there are several threads on this from the past.
QUOTE=ECR]Use the speedo drive gear form a RR Classic, FRC9339 is the part #. It will cure your roughly 5 mpg overread issue.
Cheap and easy and no need for any custom work.
Most NAS 90s came with the tan drive gear that reads too high. The Black RR Classic gear corrects the issue with 2 more teeth.
Neat piece of information. Thanks for sharing it.
speedo
New Gears and WOW, 10 mph? mdmccallum Defender Technical Discussions 26 December 1st, 2011 03:50 PM
Gears vs Tires jimbemotumbo Defender Technical Discussions 21 April 26th, 2005 09:23 AM
VDO speedo for sale vlocci For Sale - Parts 3 May 2nd, 2004 12:38 PM
Speedo correction d90Monkey Defender Technical Discussions 2 April 21st, 2004 12:05 PM
4.10 gears and Detroit locker dave_lucas For Sale - Parts 3 December 1st, 2003 03:03 PM
