New Fuel Pump - Not Working - Defender Source
Old October 27th, 2015, 11:57 PM
RhinoRover's Avatar
RhinoRover
Andy
1986 D110
The system is completely dry except for a few gallons in the tank. New fuel pump, tank and recycled gas lines. I put a few gallons in the new tank, turned the key and can hear the pump run, but it sounds like its running dry. Do I need to prime the pump or something?
Old October 28th, 2015, 12:09 AM
RhinoRover's Avatar
RhinoRover
Andy
1986 D110
I also confirmed that there is no fuel at the fuel rails. Again, do I need to prime the lines/pump or release air from the lines? Is there an obvious step that I'm missing? I hate to run the pump dry anymore than is necessary.
Old October 28th, 2015, 12:27 AM
RhinoRover's Avatar
RhinoRover
Andy
1986 D110
EFI? If so the pump is submerged and no prime is necessary. There is a filter mounted on the frame rail near the tank. It might be plugged. It also gives you another place to see if you are getting fuel there.
-Jeff
That's what I was going to try next. I was delaying the installation of a new filter so I guess this is a good excuse to just get it done, now. Thanks for the help.
Do you think it's possible that I need to put more fuel in the tank since it's new? Hate to do it in case I need to drop the tank in case of a faulty pump or something.
Old October 28th, 2015, 07:56 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Like Jeff said check before the filter and replace that old one.
Double check your plumbing to make sure you didn't switch the feed & return lines.
fuel
95' NAS Fuel Gauge not working KKilo23 Defender Technical Discussions 6 June 3rd, 2014 10:41 PM
110 fuel guage not working properly Tyler Wirken Defender Technical Discussions 9 October 31st, 2012 12:19 PM
WTB Fuel Pump (not working one) NAS Broncoduecer Wanted 5 October 1st, 2012 12:09 AM
Fuel Gauge not working FlaD90 Defender Technical Discussions 6 February 20th, 2009 03:18 PM
fuel injectors not working matt Defender Technical Discussions 1 May 24th, 2007 06:28 PM
