new front discs and pads on D2, advices ? - Defender Source
Old October 24th, 2010, 11:22 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
pads are done, discs are rusty and thinner, time for a complete change.
I know it's not a defender, but any advice on what to buy will be greatly appreciated. So far i'm thinking DBA discs and genuine pads.
- Charles Eames
Old October 24th, 2010, 03:45 PM
jack SF
jack baran
95 ST yellow
hi. i dont know what DBA rotors are but i had installed stock replacement rotors by brembo and they warped.
i have never seen a genuine rotor on a disco warp.
i recomend original rotors and pads.
Old October 24th, 2010, 05:38 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
I've actually been running my original rotors for the past 50-60k miles or so w/o an issue. The original rotors/pads are the best way to go, especially when it comes to squealing and wear-time.
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old October 24th, 2010, 08:15 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
I've never had an issue with Brembo, noise or pulsation. Other than when they don't supply any for the Rover model and I have to go Genuine, I only use Brembo and Ferodo on my Rovers and my customer's Rovers.
Email is
Same place, new dogs.
Old October 25th, 2010, 01:43 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
i thought everybody was using DBA, how much are the Brembo rotors ?
- Charles Eames
Old October 25th, 2010, 09:37 PM
pushngo
Randy Williams
Justin has a new Terra Firma drilled and slotted rotor for the D2 I just got a set so can't comment on duration They are about $100 pr the Brembos are about $80
Old October 27th, 2010, 09:39 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I would strongly recommend against drilled and slotted rotors especially in a D1. Stick to genuine.
------ Follow up post added October 27th, 2010 09:41 AM ------
Actually the best rotors I've ever come across are Frozen Rotors. Last much longer, and never had one warp.
http://www.frozenrotors.com/
Old October 27th, 2010, 10:03 AM
dchapman
Daniel Chapman
1999 D1
Genuine or Ferodo pads. I'm not sure about D1's, D2's, or Defenders, but the newer LR3's, RR, and RRS's are Ferodo pads in a Genuine box.
Drilled rotors are kind of a waste, IMO, for a Disco. The holes get clogged with dirt/mud, etc...
EBC makes a rotor for Rovers with dimples rather than holes. These dimples, along with slots, still help to allow the gas to vent under heavy braking.
What ever rotor you go with, make sure it's vented.
Old October 27th, 2010, 11:13 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
i changed the pads already and put some ferodos, they're thick like hell !
- Charles Eames
pads
brake discs and pads blenkush Defender Technical Discussions 3 January 23rd, 2005 01:32 AM
