New Front Brakes Clang HELP! - Defender Source
Old August 3rd, 2014, 07:44 AM
Char01
Richard Reice
1995 D90
My mechanic - an experienced and specialized Defender Mechanic in the NE - installed a new front passenger side break-calipers and pads on my 1994 D-90 NAS 80 K miles). The brakes now make a banging or clanging noise as we drive along unless some minimal pressures is applied to the brakes. It is most annoying and proving a challenge to remedy.
Suggestions are sorely needed.
Old August 3rd, 2014, 07:57 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Loose bolts on the caliper, tighten them or bring it back to your mechanic
Old August 3rd, 2014, 08:05 AM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Yes. You should be able to work this out quickly. Let me know if you need help with this, I'm not that far from you. I bet I can guess who worked on it...
Old August 3rd, 2014, 10:11 AM
Char01
Richard Reice
1995 D90
Well, without using names it's was not a mechanic in Fairfield Cty or Westchester.
Ranker, where are you located?
Old August 3rd, 2014, 10:28 AM
rankar's Avatar
rankar
I'm in Wilton... Mechanic in norwalk?
Old August 3rd, 2014, 11:09 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Well, without using names it's was not a mechanic in Fairfield Cty or Westchester. Ranker, where are you located?
I wouldn't worry about it; might be the bolts were worn from too many brake jobs and they just backed off themselves. Brakes are a pretty standard install so I think it's less about your mechanics competence and more about something out of his control or overlooked
Old August 3rd, 2014, 11:15 AM
Are they aftermarket callipers? I've heard that the holes for the pins in the front callipers are slightly too large which can cause a clicking noise when applying the brakes.
Old August 3rd, 2014, 11:42 AM
rankar's Avatar
rankar
You're probably right about mechanic, but there is one serious hack job here that puts himself out as an expert
Old August 3rd, 2014, 01:23 PM
carlosz's Avatar
carlosz
Carlos
Brake pad hardware missing or worn out, on a defender should be a two inch long coil spring dressing the pin sandwiched in between the pads, one on each pin...rovers north or ab have them.
the truck ran like a "raped ape"
A fussy warm weather creature...
Old August 4th, 2014, 08:13 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Have you checked the dust shield?
brake
Need help with lr3 brakes. It's getting late in day phunter Misc. Chit-Chat 15 November 29th, 2013 10:41 AM
brakes, need help with part # CavemanDiesel Defender Technical Discussions 23 March 1st, 2013 01:20 PM
Formula R1X Disc Brakes - Mountain Bike Brakes bjf The Flea Market 4 May 14th, 2012 10:07 AM
Help...When I press on the brakes, I hear a knocking sound WEMICHENER Defender Technical Discussions 4 February 17th, 2007 04:24 PM
Front brakes axle shims won't fit... thewap Defender Technical Discussions 6 June 7th, 2006 11:50 AM
