New Engine Question - Defender Source
Old January 5th, 2011, 09:46 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
New Engine Question
Looking for opinions...
So, I want to consider power plant options for my 97 D90 SW (auto) and or 95 D90 ST (manual). Something that wont require transmission or drive train upgrades...anyone have any thoughts or practical experiance with this?
Also? I have seen many threads on alternator upgrades for the D90 but I cant get a good feel for what works best! I have a dual battery system and I am just looking for a higher out for increased need on the alternator. Thanks- in advance!!
Old January 5th, 2011, 10:26 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Just opinion of course but my two cents: Keep the 4.0 in the 97 and save the expense of the 4.6 engine and transmission swap. Put a 4.2 in the 95 and have fun.
You can run a 95-98 Range Rover 4.0 or 4.6 alternator in the 97, it is 120 or 130 amp output compared to the 90 amp stock D90 unit. In your 95 you can run a factory GM alternator with higher output or even an aftermarket, but will require modification to the mounting bracket, etc.
Old January 5th, 2011, 10:51 AM
I have a Range Rover 4.2 in mine and it has been great so far!
Old January 5th, 2011, 03:14 PM
Stock alternator is fine for two batteries. As far as engine upgrades, just save money for 4.6s anything beyond or much beyond that would require a new trans, espeically in the 95.
Old January 5th, 2011, 03:30 PM
The Dro
Dro
1988 Ninety
I love the power on my '97 GEMS 4.6L. If you have the time and money I recommend it.
Old January 5th, 2011, 10:18 PM
Bill Larson
Bill Larson
are our engines described as long blocks? If so British Atlantic is selling new ones for $7500.00!! I'm sure there is more to is as it is more than just a plain engine (water pump...etc.) but that price is heavy duty...
------ Follow up post added January 5th, 2011 10:21 PM ------
yeah it works just fine...you know how it is if I can get more power without major modification...why not. You never know when (or why) youre going to need it!!
engine, new engine
2.25L and 200Tdi engine mounts question Gkase Defender Technical Discussions 8 April 10th, 2009 08:53 PM
Check Engine light Question? True or False? Hammertime Defender Technical Discussions 0 April 5th, 2009 10:39 PM
Engine Oil Leak Question ronward Defender Technical Discussions 0 March 22nd, 2005 09:38 AM
