New engine - Defender Source
Old July 14th, 2012, 12:07 PM
drewpick
Drew Pickard
1994 D-90
New engine
I took my 1994 D-90 into local shop because it was making a knocking noise. He told me the head gaskets are blown. He said it could be the sleeves in the cylinders and if so it will need a new engine. Does anyone have experience with putting a new/rebuilt engine in a D90? I don't know that is makes sense to spend $2600 redoing the heads and not just putting a rebuilt engine in the truck. Any idea where to find a rebuilt engine and what it would take to put it in. Looking for suggestions from experienced D90 owners. Thanks
Old July 14th, 2012, 12:26 PM
parovertech
john palita
1973 series III,
d90 engine
I have access to a reman 4.6l shortblock set up to use in a distributor ign rover. Its one of the ones atlantic british was selling a while ago, but they no longer stock them. My cost on it is $3950 plus ship. PM me for more details
Old July 14th, 2012, 05:23 PM
Drew, any 3.9L engine from a Discovery 1 of similar years (i think up the 96) are an almost direct drop in - just make sure it's the 14CUX and not GEMS. The front cover is like a 95 D90 so it has a single serpentine belt so will need the ancilliaries or swap front covers. But you have lots of options in terms of finding a low mileage replacement or rebuilds. Also the design is basically a old buick engine so there should be lots of people able to rebuild them - it's not some exotic foreign engine. See this site for info
http://aluminumv8.com/
And I don't know how far away Pendy is from you but he rebuilt a disco engine for me years ago and I am very happy with it - in case you want to go with a trusted source and contributor to d-90.com
charles
Originally Posted by pendy
I'm here for the D's
Old July 14th, 2012, 05:49 PM
The Dro
Dro
1988 Ninety
charles
94 and 95. The 96's are GEMS.
Also, you can look for RRC's.
Discos are pretty cheap now a days.
Old July 14th, 2012, 06:00 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Segueing off Pedro, when you look at the RRC's you can consider the 4.2 out of a LWB for a minor bump in power compared to the SWB or D1 3.9.
r-
Ray
Old July 14th, 2012, 06:59 PM
You may want to get a second opinion. If you do end up needing a motor, you have lots of options.
Old July 14th, 2012, 07:16 PM
pushngo
Randy Williams
Any serp belt 3.9, 4.0, 4.2 or 4.6 will fit you need to change the front cover and add the distributor gear on most of them Bosch engines have a different cam setup not that you would want one of those
BTW it is rare to slip a liner in a 3.9 from what I have seen
Old July 15th, 2012, 06:47 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
In the last 10yrs I have had 8 3.9s with the pressurized coolant *syndrome*. 3 of them have had a slipped liner, and one of those had 2 ( it also had 1 collapsed lifter and a huge hole punched in the oil pickup screen as well as so much sludge and gunk in the motor I had to spoon out the cylinder head to get at the head bolts.... lol). The rest were head gaskets.
For a while it seemed every DII w/ 4.6 that showed up had a slipped liner........like 1 a week. Thankfully I don't work on them! That would get annoying.
Matt Browne
engine, new engine
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
Yet another engine fire chrisvonc Misc. Chit-Chat 80 August 30th, 2005 02:22 PM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
