New ECR LEDs/But still have an old problem!!! - Defender Source
Old January 29th, 2011, 03:50 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
Installed some LEDs...look great...thanks Mike!!! I still have an old problem of all of my rear lights (both left & right red/amber) flashing whenever I have the left blinker on....I've tried switching out the two relays in the fuse panel...I guess the next step is to replace them??? Any ideas? thanks
Old January 31st, 2011, 08:03 AM
s3landy
Mike Wallace
I would check all the grounds.
Old January 31st, 2011, 08:20 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
x2 on the ground and check to see if there is some trailer wiring that was added. Another possibility is the hazzard switch connection(s).
Old January 31st, 2011, 08:27 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Agreed on checking all that, especially if someone botched in trailer light wiring.
You have a short issue most likely as the brake lights and the signals are on different circuits, so something is messed up. A bad ground would typically make one side dim or do other funky things, but if you are getting the brake lamps to come on when you run a signal you have a wiring issue and you will need to trace the wires and see what is happening.
Email:
Old February 6th, 2011, 01:45 AM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
trailer wiring it twas
ecr
Help! Problem starting (95 SW) reaper99999 Defender Technical Discussions 8 March 2nd, 2006 07:22 PM
Wobbly distributor cap? and an update on my starter problem MiniGuy Defender Technical Discussions 6 January 10th, 2006 10:13 AM
Air Locker problem sflash868 Defender Technical Discussions 1 May 9th, 2005 09:40 AM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
