New diesel in old truck - Defender Source
Old September 26th, 2011, 03:34 AM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
Can we legally put a newer diesel into our trucks?(pre 97) Maybe it depends on state. Does it not matter because they don't do emissions?
What do you think about the Ford Duratorq? Just wondering because I may have found one for a decent price. I guess that price goes up when I try to make it work in the D.
Old September 26th, 2011, 03:47 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
Dennis how have you been brother? I have nothing to add to the discussion though lol
Unknown Author
716-898-8153
Old September 26th, 2011, 04:34 PM
Naplm00
Matthew
STC8358HD heavy duty clutch kit
sorry
Old September 26th, 2011, 05:12 PM
If in a state that does not do emissions, I believe the biggest issue is whether or not the "new" engine is newer than the one originally spec'd on the car. It must be the same age or newer.
Depends on the DuraTorq. The 2.4L in one flavor is the 2007+ Defender "Puma" engine, but there are variations of the same 2.4L with different power outputs. Sounds like a really complicated "upgrade" given that a 300tdi swap is fairly well documented.
Old September 26th, 2011, 08:15 PM
roverx's Avatar
roverx
Scott Preston
1969 Ser IIA Tdi Hybrid
Dennis,
It will vary from state to state. I would suggest going into DMV or Emissions testing station and asking. This is what I did. Granted it's TN but we do have emissions. I told them I wanted to install a diesel into a 1995 D1 and they walked me through it. It passed emissions w/o issue and was even changed in my reg to read diesel.
Good luck
Scott Preston
1969 Ser IIA 300 Tdi hybrid
2002 Ford F250 Crew cab 7.3 diesel
2003 VW Jetta wagon 1.9 Tdi 5 speed
1995 Range Rover Classic 300 Tdi SoftDash (My Son's)
"Be the person your dog thinks you are"
Old September 26th, 2011, 09:44 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I would think the problem would be electronics. If you could get the ECU and some wiring you may be able to get it to work. One reason the 300 is so liked is the ease of converting it into other trucks.
Land Rover 110
Old September 27th, 2011, 12:15 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
pre OBDII is better. There is a gentlemen in ME that may give you more insight.
contact me off board
Old September 27th, 2011, 09:42 PM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
Technically, to be legal, the engine has to be out of a vehicle of the same model year or newer than the vehicle it is going into. It's also supposed to retain all original emissions equipment that came on the engine. This means if your truck is OBD-II, the newer motor is supposed to be as well. After the DOT gives you the thumbs up, you should be 50 state legal.
Technically speaking of course.
Old September 29th, 2011, 11:57 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
Which Duratorq are you looking at? With the larger ones you might have a bit of a challenge with a transmission that will work.
diesel
1984 Land Rover 90 w/ 4.2litre turbo diesel Buyrovers For Sale - Vehicles 19 October 23rd, 2009 10:19 AM
Detroit Diesel artm Defender Technical Discussions 3 May 17th, 2006 05:13 PM
shop going under, diesel engines artm Defender Technical Discussions 0 May 12th, 2005 04:36 PM
WTB: Discovery w/ Diesel Power RX6RCROL Wanted 2 March 2nd, 2005 12:42 AM
D110 Diesel conversion, towing. Kerr Defender Technical Discussions 3 May 5th, 2004 06:26 PM
