new coil wire - Defender Source
Old February 17th, 2008, 09:51 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
new coil wire
So I just bought new wires, plugs, dizzy cap, and a new rotor. I was excited to see that the new coil wire has a rubber 'boot' around the coil end, but I can't figure out how the boot goes around the coil. This seems like it should be relatively straight forward but I am not finding it to be as intuitive as I thought it would be. The other two connections at the coil make it impossible for the boot to cover the end of the coil. Not to mention that the boot itself seems to be a little big for coil. Does anyone have any experience with this new boot on the coil wire?
I haven't played with it too much, but when I get the chance I may try flipping the coil around so the wires come out the top, and just try folding the other wires around the side of the coil. Any other ideas?
Old February 18th, 2008, 06:30 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
I took some pics of the new coil wire. Also, I was looking at my invoice and it describes the new wire as for a 4.2L motor (I've got the 3.9 like most). Does anyone know if that difference would make a real difference? I mean... a coil is a coil is a coil... right?
ID:	12211   Click image for larger version
Old February 18th, 2008, 06:51 PM
i think it might be a different length. When I bought my Magnecor plug wires I had two wires for the coil. One ended up being the perfect lenth for the coil for the 4.2 LWB so that where it went.
Old February 18th, 2008, 07:12 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Are coils supposed to be mounted point down, point up, or does it matter? Mine is point down and, before I filled the cup with silicone, would sometimes get water in it and die during creek crossings. Thing is, most my wires are too short to have it point up, but I could probably make it work.
Old February 18th, 2008, 09:37 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
I put the old wire along side the new one and they are about the same size. Currently my coil is mounted point down, but i think the cover would work better (since physics says water goes down) if the coil was pointed up. My dilemma is getting the rubber cover over the coil while it's pointed down; it's just too crowded down there.
I am gonna try to get the coil to point up this weekend and will report back for those who are interested.
coil
COIL (ignition) questrion rover4x4 Defender Technical Discussions 6 September 7th, 2010 08:00 AM
wiring new coil help? mattdh Defender Technical Discussions 2 April 19th, 2005 08:13 AM
Needed: Coil Wire Hans Wanted 3 January 27th, 2005 10:19 AM
