New Bulkhead - Defender Source
Old July 9th, 2007, 02:29 PM
New Bulkhead
To those that have replaced a bulkhead, what are the current bulkheads that rover is selling? Do they have the NAS brackets? What mods need to be done? (BTW this is using 1993 110 NAS bulkhead stuff bolted onto a new bulkhead)
Ron
Old July 10th, 2007, 06:36 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Not sure what you refer to as "NAS brackets" but all the bulkheads I've had recently (a dozen or so) have been set up for about anything I've ever seen bracket wise......V8, Tdi etc. and the brackets for the latest (Td5) style dash, which can be modified easily for the older style and is the only modification I have been doing other than galvanizing.
Matt Browne
Old July 10th, 2007, 08:42 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Just like above.. You have to just move a few brackets from the NAS unit and put them on the new one. Also maybe drill a few holes for wiring or something. Very easy.
Legend in My Own Mind.
Old July 11th, 2007, 06:34 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Haven't had to add any brackets or drill any holes, actually had to cut a few things off......it's all there....and then some.
Matt Browne
Old July 11th, 2007, 03:09 PM
Ok, good to know. I wanted to know if I had to transfer the NAS V8 brackets. Mike at LR West Chester is getting some in and since he is local and great to work with I am going to pick one up and have him sublet the painting and I wanted to make it correct before sending it to be sprayed (no place around here to galvanize it).
Ron
Old July 11th, 2007, 08:50 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
If you are going truly "stock" NAS 110 that exact bulkhead is NLA.
Easy to use an EFI replacement though, but you will need to make some changes. The hole for the EFI harness is not there, nor is the cabin recirc. opening for the heater and a few other minor bits. As far as the major fit, it will fit, but there are small changes needed to be made to run some of the NAS 110 stock equipment. All easy to see when you compare the 2 bulkheads side by side.
Email:
Old July 12th, 2007, 08:47 AM
ECR's Avatar
ECR
Yup, they are ventless due to the way the HVAC system works, but there is still one part # bulkhead that works in that application. I'll try and dig it up. That bulkhead does not have the EFI set up on it though (the bracket for the maxi-fuse box and the air cleaner mount), and it is missing a few holes. But with a little "cut and paste" you can make it "correct" for an NAS 110.
But... I sure as @$@& would suggest that you skip all that NAS 110 AC/ heat BS and install the later model parts. It makes everything work better and makes the right bulkhead much easier to source.
So the short answer is bulkhead for a "modified/ updated" NAS 110... easy.
Bulkhead for a truly "all stock" NAS 110... doable, but not available "off the shelf".
Email:
Old July 12th, 2007, 09:48 AM
Mike et al.
Thanks for the input. I have a bunch of vents floating around so that is not a big deal, but I should get them primed now for paint. My plan was to fit the NAS 110 HVAC and not spend the $$$$ for a new AC and heaterbox so it looks like I will have to cut a few holes and fabricate a way to lock the vents closed. Oh course, with land rover these days Mike is not even sure what bulkheads are showing up.
Ron
Old July 13th, 2007, 02:19 AM
Shane@EVS
Roverhybrids
So with the NLA NAS D110 bulkhead does that mean I could trade my NOS NAS D110 bulkhead for a running and drivable NAS D90?
Old July 13th, 2007, 10:31 PM
ECR's Avatar
ECR
I think you'd be SOL in trying to trade your NOS NAS bulkhead for an NAS 90. Someone might jump for that trade PDQ, but you'd likely end up with a POS NAS 90 and be wishing you still had your NOS NAS bulkhead while you sat around and said WTF. It all sound like a big PITA.
Seriously though... an hour with a welder and a new cheap bulkhead is suddenly NAS 110 spec.
Email:
Bulkhead Rust TurkD90 Defender Technical Discussions 4 May 14th, 2005 05:06 AM
Bulkhead Questions JimC Defender Technical Discussions 19 October 27th, 2004 01:00 PM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
Help with installing bulkhead on chassis Chris Cox Defender Technical Discussions 2 June 5th, 2004 09:33 AM
bulkhead and wiper stud fitting problem mattdh Defender Technical Discussions 3 April 2nd, 2004 09:42 AM
