new brake lines - Defender Source
Old October 5th, 2007, 06:43 PM
cneal
Charles Neal
97 d-90, 99 & 04 disco's
new brake lines
I need some help. I want to replace my brake lines with new extended ones but don't know how to do it. Can't be that hard, however, I would like a set of instructions. Did a search but came up empty.
Chuck.
Old October 7th, 2007, 10:08 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Unscrew old brake lines, screw on new ones, bleed brakes. Keep the work area clean to avoid getting crud in the system.
Old October 7th, 2007, 11:27 AM
Firefighter2904's Avatar
Firefighter2904
jason
97 d-90
do your self a favor, have a buddy with you when you bleed brakes or invest in the bleeder pump sold by atlantic british or rovers north so you can do it by yourself.
now might also be a good time to change the fluid all together.
Jay
Old October 7th, 2007, 09:17 PM
If you have some rust under your truck, spray the connections with PB Blaster the night before.
Old October 7th, 2007, 10:30 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
Originally Posted by Firefighter2904
now might also be a good time to change the fluid all together. Jay
There is enough fluid loss between changing the lines and bleeding them the fluid will be renewed, at least thats my experience.
Also get brake line wrenches, the box end ones with the slot to fit the line through. I think the size is 7/16.
Also dont be afraid to heat the fitting a bit with a propane torch to help it brake loose.
Good Luck
--Benjamin Franklin
Old October 9th, 2007, 03:42 PM
cneal
Charles Neal
Thanks. I guess the advice is to just go for it. I have done alot of work on my vehicle myself, however, I've always left the brakes to someone else. Just paranoid I guess.
Is it really worth buying a bleeder pump? Can you rent them?
Chuck.
Old October 9th, 2007, 03:52 PM
a buddy, a piece of hoseline, and a mason jar will do. bleeder pump is if you want to do it yourself.
brake
Brake lines replacement ... Retrofit Defender Technical Discussions 9 December 6th, 2006 12:25 PM
extended brake lines jimmy salmon Defender Technical Discussions 12 February 27th, 2006 11:07 AM
Clogged brake lines? Heath Defender Technical Discussions 11 February 24th, 2006 08:39 AM
Hard brake lines! TwisteD90 Defender Technical Discussions 10 October 10th, 2005 12:12 PM
Stainless steel extended brake lines Chris Cox For Sale - Parts 1 February 8th, 2005 01:34 PM
