New Amsoil MTF - Defender Source
Old June 15th, 2005, 09:01 PM
PT94D90's Avatar
PT94D90
Phil
Currently Defenderless
New Amsoil MTF
Anyone have any thoughts on the new MTF that Amsoil has come out with?
http://www.oilsandlube.com/manual_trans75.htm
Old June 15th, 2005, 09:33 PM
TOO THICK!
Use redline MTL. Not Redline MTF. ONce again. Redline MTL.
MTL good, MTF bad.
Old June 15th, 2005, 09:41 PM
PT94D90's Avatar
PT94D90
Phil
They actually have 2 new ones, here is the other. It's lighter.
http://www.oilsandlube.com/synchromesh_trans5w30.htm
Old June 15th, 2005, 09:42 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I recently did a fluid change and switched from Mobile 1 synth (or it might have been Castrol 4x4 synth) to MTL and I removed a bunch of gunk from the filter. Alot, actually. Nothing hard, more like thin sheets of flakey black paper like crap. I refilled with MTL. Now I snick going into 2nd and if the truck is cold, it grinds into second. When warm, it is not too bad. I know part of this is the cleaner fluid, but I have to say for the price, I would hesitate getting the MTL. Now, if I refilled with some other fluid, the snicking may have been 10 times worse, so I am not saying it WAS the MTL, but I won't know till I change the fluid again--and having spent $60 on the fluid, I am not going to do it just to check. FWIW.
Old June 15th, 2005, 10:17 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Hmm... You have a 94 D90 5spd R380 and you removed thin sheets of flakey black crap from your transmission filter ? Where is that 'transmission filter' located ?
Please forgive my ignorance.
Nicholas Orros
P.S. Great post... I haven't been keeping up with the oil shtuff lately! I'm on it the next time I change the fluid out, maybe sooner. It shifts ok... so far, a little sticking in 2nd but most do.
Old June 15th, 2005, 10:21 PM
MTL is thicker so the synchros do not go as quick when cold. This is good as they do not wear as much as the MTL cushions them. If you are snicking at all you are shifting too fast.
If you want fast shifts run ATF, but the synchros will die quick.
Old June 15th, 2005, 10:41 PM
I just switched from Mobil 1 Synthetic ATF (it was available) to Redline MTL. The ATF felt like shifting a box full of water - the MTL feels like its full of lube. That makes me happy.
Old June 15th, 2005, 11:24 PM
stevewhitaker's Avatar
stevewhitaker
Stephen Whitaker
1994 D-90
Put the 5/30w Amsoil MTF in my '94's R380 and it seems fine - a definite improvement over whatever was in there before. I am not sure how this Amsoil product compares with the Redline MTL; the write-ups make it seem they are roughly equivalent in lubricating and cushioning the gears and synchros. Perhaps one of the lube gurus will enlighten us all. (?)
Old June 19th, 2005, 05:44 PM
Redline MTL is the best thing you can do for your gearbox
Old June 20th, 2005, 12:42 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Chris do you have a lT77 or R380?
legend in my own mind
Old June 20th, 2005, 08:25 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Well, it turns out that the flakey bits were actually paint that they use on the inside of the gearbox--it is so that the oil drains off the surface easier (they still use this "technique"). The gearbox only snicks in cold weather and then just for the first 5 minutes or so, then no snicking at all. I say snicking, but when really cold, the second gear actually grinds a little. I have no snicking once warm. I suppose I could be convinced that MTL is doing its job...
Old June 21st, 2005, 01:11 AM
If it grinds you are shifting too fast. Slow it down and no grind.
Old June 21st, 2005, 01:21 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
and pendy, it is a 77
Old June 21st, 2005, 01:27 AM
Oh, well that is why it grinds
Old June 21st, 2005, 01:55 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
:-) Yeah, sure wish it was an R380. No one ever complains about those grinding. Oh, to dream.
Old June 21st, 2005, 02:06 AM
My R380 used to grind second, but I just learned to drive it right.
Old June 21st, 2005, 02:16 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
always granny shifting, not double clutching like he should..... XXX
Old June 21st, 2005, 08:45 AM
PT94D90's Avatar
PT94D90
Phil
I agree with Ron, the only time I've had any grinding or "snicking" is when I've shifted too fast. A lot of good feedback in this post. I guess at some point I'm going to have to try the Redline MTL, but for the past year I've had Amsoil ATF in the gearbox and I have no complaints. It shifts smoothly cold or hot (definitely a bit smoother when warm though). That's why I was curious about these two new products from them. How often do you guys change that gearbox oil, once a year?
transmission drain and fill rover4x4 Defender Technical Discussions 24 November 16th, 2011 02:31 PM
Are K&N, Amsoil, etc air filters worth it? cdb Defender Technical Discussions 8 July 19th, 2007 08:38 PM
Amsoil vs other synthetics loykd Defender Technical Discussions 6 July 4th, 2005 11:06 PM
Synthetic or Dino, What do you use??? javelinadave Defender Technical Discussions 16 February 8th, 2005 07:33 PM
AMSOIL Synthetic Products javelinadave The Vendors Loft 0 January 5th, 2004 05:13 PM
