new Alpine radio connection - Defender Source
Old June 13th, 2011, 10:43 PM
ditskovich's Avatar
ditskovich
dmitry
Range Rover Sport 2013
Do I connect wires straight forward according to color, or, I remember somebody mentioned, that some wires should be switched?
Old June 13th, 2011, 11:25 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Get a diagram for both wiring harnesses and match up the wires by function. It may be color-for-color but I never trust it. I match them by function.
Old June 14th, 2011, 07:12 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
really the only wires to worry that could be switched are the ignition and battery...with a test light you can identify these two pretty easily
Old June 14th, 2011, 07:43 AM
Naplm00
Matthew
Yup and if you need to figure out where a speaker is you can brush its leads on a ninevolt. The one that makes noise is the one ur looking forum
Old June 14th, 2011, 08:04 AM
James Pierce's Avatar
James Pierce
James Pierce Jr.
Definitely not the same. Should have wrote it down. As Chris said, match by function, surely someone on here has the 90 harness diagram.
Old June 14th, 2011, 10:36 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Check the FAQ. It is in there.
Old June 19th, 2011, 08:52 PM
ditskovich's Avatar
ditskovich
dmitry
radio is in
I was wandering if it is possible to attach wires the way, that radio is connected, even though the car is off.
Old June 24th, 2011, 06:47 PM
sandman913's Avatar
sandman913
1985 110 200 Tdi
all you need...
http://www.defendersource.com/forum/...ghlight=97+NAS
Old June 24th, 2011, 09:34 PM
ditskovich's Avatar
ditskovich
dmitry
Got it.
The purple car wire actually became red in Cratchfield adapter connection. That is why I could not get power.
After I attach red ( hot constant battery) to yellow stereo wire, start working right away.
Thanks.
radio
Which Radio plugs work in 95 D90? Gkase Defender Technical Discussions 11 July 25th, 2011 12:41 PM
iPod connection to stock radio ditskovich Defender Technical Discussions 5 April 18th, 2011 10:39 AM
'97 Defender radio & changer setup? Defender50th Defender Technical Discussions 6 September 27th, 2005 11:22 PM
Electrical short with my radio ? paulb Defender Technical Discussions 4 August 11th, 2004 12:25 PM
97 radio plug arrangements Gkase Defender Technical Discussions 1 October 6th, 2003 06:58 PM
