New 200tdi engine mount equals new back massager - Defender Source
Old November 9th, 2015, 09:00 PM
Werrea's Avatar
Werrea
Anthony Werre
08 LR3
This past weekend I replaced a broken engine mount. I ordered through a common vendor and got part number anr1808g. It was supposed to be softer. The wrapper said Britpart.
It is so horrific. Might as well be a poly or solid mount. My teeth chatter.
Please help and offer solutions.
Anthony
Old November 9th, 2015, 09:20 PM
Doesn't the G suffix usually indicate Genuine?
Old November 9th, 2015, 09:26 PM
Even if your engine mount was solid aluminum, it shouldn't shake that much.
Something else is wrong, and may be to the reason why the original mount failed. Britpart is a distributor and makes nothing. Having their name on a bag gives no clue to the origin of the part.
Old November 9th, 2015, 09:40 PM
Have you ever driven a truck with QT motor mounts? Its pretty bad on a V8 and instantly noticeable.
Old November 9th, 2015, 10:54 PM
defendernut
Brady
1984 D90 200tdi
Anthony -
I had the same problem. I was reaching out to anyone that could offer any advice for my 200Tdi on a 1984 D90. The solution (Not perfect but damn near) was from purchasing the REAL RANGE ROVER mounts. Not BritPart. I had them replaced at SafariHP. The mounts, I believe were about $50-60 each. But well worth the money. It really made all the difference in the world. I'd give Stephen a call. Ask him what part number that he put on Brady's D90 truck.
Hope that helps.
Brady
321-377-3049 cell
Old November 10th, 2015, 04:27 AM
Does the shaking occur at idle only or all through the rev range?
Old November 10th, 2015, 06:06 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
It does.... it means that it was shipped out to the lowest bidder and made of the crappiest available ingredients.
avoid britpart at all costs!
Old November 10th, 2015, 06:47 AM
Googling ANR1808 results in many options. Surprised at the massive variation in cost. It's not something to compromise on.
Old November 10th, 2015, 06:54 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
lol- my old silver truck had QT mounts! you're right; instantly noticeable,
Rent my
Old November 10th, 2015, 09:00 AM
Werrea's Avatar
Werrea
Anthony Werre
08 LR3
The motor runs great. The shaking is at idle. The motor mount is transferring all vibrations to the chassis. That is the problem. Even when driving down the road I can feel more now.
I haven't been in a TDI that doesn't shake at idle. But to be clear, I am not experiencing anything abnormal. It's not shaking violently.
Old November 10th, 2015, 09:10 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I used to get a headache in Brandon's poo brown before he fixed the idle problem
Old November 10th, 2015, 09:18 AM
Werrea's Avatar
Werrea
Anthony Werre
08 LR3
I ordered the "g" part number which was supposed to be genuine.
Old November 10th, 2015, 09:20 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Anthony
This winter I promise to have a set of hydraulic filled motor mounts that absorb vibrations.
In the meantime keep the number for your dentist in case any fillings shake out.
RDavisinVA
Old November 10th, 2015, 09:23 AM
BlackField's Avatar
BlackField
Oscar
D110
Originally Posted by rdavisinva View Post
This winter i promise to have a set of hydraulic filled motor mounts that absorb vibrations.
I was just trying to dig that post up to see when your motor mounts are coming out. I'm on the list.
Old November 10th, 2015, 09:51 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Yes you are, Oscar!
RDavisinVA
Old November 10th, 2015, 10:05 AM
The "G" parts are OEM, not genuine.
Old November 10th, 2015, 10:11 AM
I disagree. I've gotten genuine dowty seals in Britpart bags.
Old November 10th, 2015, 10:28 AM
Werrea's Avatar
Werrea
Anthony Werre
08 LR3
This winter I promise to have a set of hydraulic filled motor mounts that absorb vibrations. In the meantime keep the number for your dentist in case any fillings shake out.
I have read about your solution. Much looking forward to it. Please, please put me in the front of the line. This is my daily driver and driving it became a whole lot more annoying. My eyeballs vibrate.
Old November 10th, 2015, 01:21 PM
Try a trick that Uncle Douglas taught me - raise the idle rpm by a little bit. It made a huge difference in my truck.
The new motor mount will soften out with time.
Old November 10th, 2015, 01:46 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
That's what I told Brandon...worked pretty well
Mfr. Rebate Equals a 40%, 50% or Even 70+% Savings RockAuto The Flea Market 0 March 26th, 2015 04:03 PM
engine and back harness ditskovich Defender Technical Discussions 3 September 18th, 2009 04:46 PM
Is it ok to mount a 200tdi to an engine stand? dave_lucas Defender Technical Discussions 15 July 6th, 2009 12:34 PM
Rear light mount bracket four bolt mount riser thing-a-ma-bob evilfij Wanted 14 June 5th, 2009 06:11 PM
WTB Wing Mount Pick Ax Mount NashvilleRover Wanted 1 September 13th, 2008 10:29 PM
