New 200tdi engine mount equals new back massager - Page 2 - Defender Source
Old November 10th, 2015, 02:05 PM
BlackField's Avatar
BlackField
Oscar
D110
When you say raise the idle... Are we just adjusting the accelerator cable or is there an idle set screw or something?
Old November 10th, 2015, 02:07 PM
Personally... I use a genuine hand throttle and set the first notch up for a smooth idle. I can then easily drop to minimum idle for off road use.
Werrea's Avatar
Werrea
Anthony Werre
08 LR3
Try a trick that Uncle Douglas taught me - raise the idle rpm by a little bit. It made a huge difference in my truck. The new motor mount will soften out with time.
Okay, I raised the idle with the idle screw. Made some improvement. Really smoothed out if I raise more, but don't want to burn rubber every time I let the clutch out.
I had no idea an eyeballs can vibrate. Who knew!
Old November 10th, 2015, 02:23 PM
Just the cable.
Old November 10th, 2015, 02:26 PM
There is an idle set screw. You should not be purposely removing tension from the cable.
Old November 10th, 2015, 03:05 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Where is the idle set screw?
Old November 10th, 2015, 03:09 PM
Where the throttle stops against is an adjustable screw.
Old November 10th, 2015, 03:37 PM
Yeah, good point. That's what I was referring to. Thanks John.
Old November 11th, 2015, 06:34 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Thanks, I've always just messed with the cable.
Mfr. Rebate Equals a 40%, 50% or Even 70+% Savings RockAuto The Flea Market 0 March 26th, 2015 04:03 PM
engine and back harness ditskovich Defender Technical Discussions 3 September 18th, 2009 04:46 PM
Is it ok to mount a 200tdi to an engine stand? dave_lucas Defender Technical Discussions 15 July 6th, 2009 12:34 PM
Rear light mount bracket four bolt mount riser thing-a-ma-bob evilfij Wanted 14 June 5th, 2009 06:11 PM
WTB Wing Mount Pick Ax Mount NashvilleRover Wanted 1 September 13th, 2008 10:29 PM
