needle scalers? - Defender Source
Old February 24th, 2009, 04:21 PM
Abrooks's Avatar
Abrooks
Tony Brooks
needle scalers?
Anybody have experience with these? How effective are they at removing bondo?
Old February 24th, 2009, 04:29 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Yah, it's on the rear fender of my shitbox daily driver. Truthfully it IS the rear fender of the daily driver. Looks to be as much as 4" deep, I'd like to remove it to pull the dent. Are they just too aggressive for sheet metal?
Thanks for the advice!
Old February 24th, 2009, 06:03 PM
Borrow my Porta Power (currently in Galpins garage). You can push the dent out using hydrolics pretty precisely and the bondo should pop off.
Old February 24th, 2009, 10:10 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
I had good luck using one to remove a waxoyl like coating on a chassis prior to sandblasting, but as it has been said, you'd tear up anything lighter.
Old February 25th, 2009, 02:50 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I would never use a needle scaler to remove bondo. They are great for removing rust and stress relieving welds however.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 25th, 2009, 02:58 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Is this on the red Miata? Oops, I just dimed you out in front of everyone...
I use a torch to heat it up and then I break it free with a chisel. Usually heat will break the bond between the bondo and the metal. Do it outside though!
Semper Fi!
Fuel Pump Help MJager Defender Technical Discussions 4 May 23rd, 2009 03:39 PM
Tire Repair Davis M Defender Technical Discussions 11 December 29th, 2008 03:52 PM
Yet another Overheating Post Epsom_D2 Defender Technical Discussions 20 June 19th, 2007 01:15 AM
Temp Sender Location DJ Menasco Defender Technical Discussions 10 August 28th, 2006 01:24 AM
fuel guage needle moving chirider Misc. Chit-Chat 1 November 20th, 2004 09:22 AM
