need wobbly brake pedal advice. - Defender Source
Old May 24th, 2004, 09:47 AM
januconn92's Avatar
januconn92
Jan Jurgielewicz
97 D90 #1477 Green ST
Hello All,
I have a 97' and have noticed that the brake pedal wobbles a little bit side to side, I looked under the hood in the black brake box and see the pedal has a bolt and cotter pin, there seems to be some play but is this normal?? Is there anyway to tighten it a little?? Any help / feedback is appreciated..
Jan
Old May 24th, 2004, 09:54 AM
Mine wobbles a little. I never played with it to try and fix it. I just figrued thats how they are.
Old May 24th, 2004, 01:34 PM
same here
Old May 24th, 2004, 03:27 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
When I first noticed it, visions of the pedal falling off while driving motivated me to look further. I could never find anything loose. At least there is a hand brake.
"Uhh...I think they all leak like that."
Old May 24th, 2004, 03:53 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
there are brass bushing in them.. you can install new ones but have to remove the pedal box to do it.
Legend in My Own Mind.
Old May 24th, 2004, 03:57 PM
januconn92's Avatar
januconn92
Jan Jurgielewicz
remove the box, hope not
Randy (& board),
You think it is worth it or more importantly, could anything get damaged bot a little play in the pedal?
Jan
Old May 24th, 2004, 04:13 PM
Been driving for the last 15k with it like this and I've been in a few panic braking situations with no problems.
brake
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
Parking brake retrofit advice Abrooks Defender Technical Discussions 5 April 13th, 2009 11:39 PM
Bling - Billet aluminium pedal covers Defender50th Misc. Chit-Chat 2 April 26th, 2005 03:30 PM
brake pedal mattdh Defender Technical Discussions 1 February 12th, 2005 05:35 PM
Brake pedal is hard!!?? Vadim Defender Technical Discussions 9 January 25th, 2005 01:09 PM
