Need to rent or borrow a Rivnut tool. - Defender Source
Old June 8th, 2015, 04:48 PM
Funtogun
Robert Lewis
1994 D90 ST
Hey guys...
I need to borrow or will "rent" a Rivnut tool.
Need set up for 6mm aluminum nuts...and needs to be like a rivet gun, not the block type as I am using it on the hood close to the angles and the block type won't allow me to index the rivnuts correctly.
I only need it for a day and it will be back to you.
Funtogun/Robert
Old June 8th, 2015, 05:44 PM
Sticker shock:
McMaster-Carr
Now if you have enough room to swing a wrench you can make a rivnut tool from a nut and a washer. Nut should be M6. Drill out the threads with 6mm drill. Put your M6 bolt thru washer then thru dilled out nut, then into rivnut. Use end wrench to hold nut stationary while turning M6 bolt until rivnut is seated. Remove bolt and repeat.
Old June 8th, 2015, 06:34 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Having done both methods I would go with the actual tool hands down every time. For $15 it's a no brainer.
Old June 8th, 2015, 07:05 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
yes bought a whole kit on ebay for $40
good luck with your search
Old June 8th, 2015, 07:22 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
I picked up the mcmaster one with a ton of rivnuts. Worth every cent when you need it.....
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old June 8th, 2015, 09:00 PM
Funtogun
Robert Lewis
1994 D90 ST
I ended up going the "do it today" route and did 11 of them by hand with a nut, bolt, and washer. If I was going to do more...then the tool sure would be handy
ID:	122595   Click image for larger version
Wanted (to borrow) Riv-Nut tool in NOVA Firemanshort Misc. Chit-Chat 24 January 13th, 2015 05:25 PM
Rivnut Tool javelinadave Wanted 15 November 8th, 2013 06:36 PM
Another rivnut/ rivetnut post Turbofan Defender Technical Discussions 26 June 4th, 2010 11:52 AM
Fiberglass Hardtop - Rivnut? themaxx Defender Technical Discussions 10 August 2nd, 2009 11:58 AM
rivnut gun mattdh Defender Technical Discussions 6 March 30th, 2004 06:46 PM
