Need To Lock My Tailgate From The Outside - Defender Source
Old April 16th, 2015, 12:55 PM
The Wizard's Avatar
The Wizard
Douglas Wozny
1994/ Defender 90 #500
"A small job that makes a big difference in a 1994 Defender 90 is to add a locking tailgate latch. The 1994 D90s did not have an exterior lock from the factory, so to lock the tailgate you had to crawl through the interior to lock and unlock the rear gate. Fortunately we have a jig that sets up the hole for the 1995 style look system in exactly the right place, so we simply install a later style latch with a lock. We then match the lock cylinder to the other 2 doors so that one key does everything and poof... you get ease of use and a total cure to something a lot of 1994 D90 owners don't like. No longer will you have to crawl over the seats in this D90 to lock and unlock the tailgate. It is all easily done from the outside just like on the 1995 and 1997 D90s." Quote taken from east coast rover's website.
I am getting to old to be crawling through the interior to unlock and lock my rear gate. How difficult is it to install a "1995 style lock system" to the rear "gate" of my 1994 D90? Do I need a "jig" to do this? Where do I get the parts? Can anyone "walk" me through the process?
The Wizard
To paraphase "Oddball" (Donald Sutlerland, "Kelly's Heros", 1970) "I only drive 'em, I don't know how to fix them."
1994 Defender 90 No. 500
Old April 16th, 2015, 01:05 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Is your a ragtop or a hardtop?
Old April 16th, 2015, 01:33 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
You need a new latch like the 1995-1997s have (easily sourced) and you will need to drill a large hole in your tailgate that the tumbler barrel goes through. You can make a template of where the large hole needs to be once you get the new latch. Its a pretty big hole. You could drill a hole and then grind the rest, or use a hole saw. We use uni-bits for a clean hole.
The only real trick is that you will not have a lock cylinder (key) for the new latch. So you can either go without a key (but then anyone can undo the lock with a screwdriver) or you can change all the lock cylinders in your 90 out for new ones, or if you are near a place like ECR you can have them make you a lock cylinder that matches your current key.
Email:
Old April 16th, 2015, 01:39 PM
What mike said. I had all the parts and then realized I rather have someone break in than cut my softtop.
Old April 16th, 2015, 01:51 PM
The Wizard's Avatar
The Wizard
Douglas Wozny
Mine is a hardtop!
The Wizard
Old April 16th, 2015, 02:27 PM
ECR's Avatar
ECR
Mine is a hardtop!
In 1994 that doesn't matter. It can be a soft top or the POE (port of entry) Wagon and the tailgate lock is the same (in 1994).
Email:
tailgate
FQR100590 - Lock - Tailgate BostonAndy For Sale - Parts 5 July 8th, 2015 04:19 PM
To tailgate or not to tailgate Craigd Defender Technical Discussions 3 November 24th, 2009 01:43 PM
Soft Top Tailgate Bar & Tailgate Clips jimngo Wanted 1 October 31st, 2006 02:19 PM
Front shocks outside of coil springs? castlerock4x4 Defender Technical Discussions 19 May 12th, 2004 04:23 PM
lock the tailgate?? Campbell Defender Technical Discussions 9 December 8th, 2003 05:46 PM
