Need to change front shock bushings - Defender Source
Old August 9th, 2014, 10:55 AM
Hats the best way and tool to grip the shock to get the bottom nut off?
Clearly gripping the bottom isn't ...
Old August 9th, 2014, 11:06 AM
if you are keeping the shock, maybe a strap wrench on the shock tube. Whatever you use you'll need copious heat and releasing fluid on the nut. I have had to dremel through the nuts before where I wanted to save the shocks and they were firmly seized. Dremel makes a tungsten carbide cutting bit that will surgically cut through any fastener and enable you to save the threads underneath.
http://www.dremel.com/en-us/Accessor....aspx?pid=9901
Old August 9th, 2014, 11:27 AM
Thanks. Tool shopping time!
Old August 9th, 2014, 12:07 PM
pipe wrench or channel locks, not sure if you are replacing the shocks
Old August 9th, 2014, 01:14 PM
I just ordered a box full of stuff from the UK but didn't get shocks. Probably should have done! Dammit.
Might try and source some genuine puma shocks and go for the plush ride ...
Old August 9th, 2014, 06:11 PM
-Jeff
x2. Those have many great uses including pulling out main bearing caps. I don't actually have a set, but I borrow my coworker's all the time.
Old August 9th, 2014, 06:14 PM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
I just ordered a box full of stuff from the UK but didn't get shocks. Probably should have done! Dammit. Might try and source some genuine puma shocks and go for the plush ride ...
Go to Toms he'll use his jaw.
Why are top bushings being shredded on shock tower landrovernewbee Defender Technical Discussions 14 July 15th, 2014 01:02 PM
oil change/oil cooler line change sirjond Defender Technical Discussions 12 January 25th, 2013 03:01 PM
Shock bushings or new shocks dnp Defender Technical Discussions 6 August 30th, 2011 02:35 PM
Need to change front timing cover seals, auto trans flush... NY/NJ/MA/VT/CT area? KKilo23 Defender Technical Discussions 4 September 21st, 2009 03:35 PM
shock towers/shock removal rover4x4 Defender Technical Discussions 8 May 8th, 2007 06:28 PM
