Need to buy 110 rear crossmember - Defender Source
Old August 21st, 2013, 05:28 PM
Naplm00
Matthew
Who should I buy this from?
Id prefer galv and need extensions. Frame is an original 86 with a ~18gallon diesel tank in the rear.
RN has em for $500 plus shipping
any other options?
Old August 21st, 2013, 05:42 PM
Shawn's Avatar
Shawn
shawn Orth
1994 Defender 90
Call Stephen at safari HP
Old August 21st, 2013, 06:05 PM
SafariHP's Avatar
SafariHP
Safari Heritage Parts
1983 Defender 110
Thank you for the call Matt and thanks for the plug Shawn.
Scott :-p
2450 North Forsyth Rd
Winter Park, FL
(407)517-4983
Old August 22nd, 2013, 11:53 AM
aclarke's Avatar
aclarke
Andrew Clarke
1986 110 CSW 200tdi
How are you going to weld the crossmember in if it's galvanized? I was going to go that route, but since I couldn't find anyone with the apparatus to weld galvanized steel and/or willing to do it, I ended up with a painted one.
1986 110 CSW 200tdi (
Old August 22nd, 2013, 12:18 PM
Just grind off the galvanizing around the ends where you weld it before you do. No big deal.
Old August 22nd, 2013, 12:23 PM
aclarke's Avatar
aclarke
Andrew Clarke
1986 110 CSW 200tdi
Yeah, maybe I should have pushed harder on that front. Nobody wanted to touch galvanized metal and eventually I just left it at that.
Old August 22nd, 2013, 06:40 PM
Muratic acid removes the galvy nicely too
Originally Posted by pendy
I'm here for the D's
Rear crossmember and Bumper kennybahr Defender Technical Discussions 7 July 18th, 2008 10:57 PM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
Rear seating options in 110 gowyn Defender Technical Discussions 6 March 13th, 2005 01:04 PM
