Need suspension advice - Defender Source
Old January 19th, 2006, 11:01 PM
fleabus's Avatar
fleabus
Dan
None :(
I am about to install an ARB/XD9000 and it is time to upgrade the suspension. This is my daily driver and occasional offroad vehicle, so on-road comfort is a major factor. I am looking to put together a 2" lift with fox shocks, but I am not sure which springs to go with (RTE, OME, etc.).
Also, I noticed RTE sells rear shock mounts, but not sure about the front (eye mounts on the fox shocks, right?). I've seen a lot of recent posts about shock mounts, but what is the best way to mount the fronts?
Thanks in advance for any advice.
-Dan
Old January 20th, 2006, 08:46 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Mine is my only truck and I've had no complaints from the OME springs I put on after the bumper and winch install. I've got eye to eye on the rear using the RTE mounts. I bought a pair of D2 shock towers and will talk to steve at RTE about a set of lower eyelet mounts for the front when I finaly have some spare cash.
Jimmy Buffett
Old January 20th, 2006, 09:18 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
RYM 2" RR4's I believe will do you solid in the front and RR3's in the back. Great spring and no sag. I woul dlook into the rockware rear shock mounts. you could run a 14" shock then and they come with the lower mounts also for eye to eye setups.
Legend in My Own Mind.
Defender suspension advice defendercr Defender Technical Discussions 7 July 16th, 2009 07:01 PM
Suspension setting advice needed (britpart springs) JFD Defender Technical Discussions 2 September 12th, 2007 10:23 PM
Requesting a little suspension advice nmc Defender Technical Discussions 9 March 19th, 2006 01:09 PM
Advice on buying my first D90 mtbrooks Defender Technical Discussions 7 July 19th, 2005 07:48 PM
Help: Suspension Suggestions gtg067i Defender Technical Discussions 29 January 20th, 2005 02:58 PM
