Need some help with my diff lock linkage - Defender Source
Old March 31st, 2009, 01:20 PM
bitz's Avatar
bitz
Jon
NAS D90, 85 D110 CSW, 66 Dormobile
Trying to do step 42 in the attached pdf. It's tight as shite in there and once you get the clip of there is no room for the pin to come out. It just hits up against the t-case. Any tricks?
Old March 31st, 2009, 01:56 PM
Probably have to undo the lock nut on the rod side.
hth
charles
Old March 31st, 2009, 02:12 PM
bitz's Avatar
bitz
Jon
The nut just loosens up the linkage rod but doesn't effect the lever on the diff. I attached a bad sketch to show a little better.
Old March 31st, 2009, 03:24 PM
Are you pulling the t-case? If so just disconnect the operation rod at the other end and leave it - that's what I've done. Obviously I transferred the rod to the new t-case, but I think I did that before I mated it to the trans. Memory is fuzzy.
Old March 31st, 2009, 03:31 PM
bitz's Avatar
bitz
Jon
No just replacing the linkage. Maybe that's still the way to go though. How is it connected to the operation rod? Is it a threaded rod? It's tough to see up there.
Oh you meen at the end where the shifter knob is?
Old March 31st, 2009, 03:42 PM
You're going up from below? Its much easier if you just pull the floor panels and tunnel. You'll be glad you did.
Old March 31st, 2009, 03:44 PM
bitz's Avatar
bitz
Jon
Yeah. Maybe that is the way to go. Thanks.
Old March 31st, 2009, 06:52 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
I know exactly what you're talking about. When I swapped my Tcase, the linkage on the donor was different, so I had to leave my existing linkage in. I ended up cutting the pin off with a hacksaw (from above) as I had a spare. When I re-assembled everything, I put the pin in from the other direction. With it in this way, it hits the Tcase when you engage the diff-lock. However, I noticed that there's quite a bit of excess length (past where the cotter key goes). After trimming off the excess, it no longer hit the Tcase. Problem solved. Hopefully this makes sense.
Chance
Old April 1st, 2009, 08:59 AM
bitz's Avatar
bitz
Jon
Thanks!
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
Diff Lock Light Wiring for 83-89 -- Modern T Case Switch Answered SafariHP Defender Technical Discussions 0 September 3rd, 2009 12:36 PM
Diff Lock Remains Engaged but Light is Off - Whats Wrong? R. Kurk Defender Technical Discussions 14 April 5th, 2009 12:01 AM
Diff Lock Andrew Vick Defender Technical Discussions 3 August 26th, 2007 10:05 AM
4 Wheel / Diff Lock hamiamham Defender Technical Discussions 4 August 7th, 2007 08:50 PM
