Need some help/advice with rear seat installation - Defender Source
Old July 19th, 2006, 03:36 PM
Paul Davis's Avatar
Paul Davis
Paul Davis
97 ST
Can someone please take a picture and or explain the seat belt and rear seat brackets for a forward facing bench seat. I thought I had this all figured out and I can't make any sense out of the buckle portion of the seat belts. If I put the female end of the buckle in the pre-drilled hole at 4 inches from the rear of the truck, then the buckles are about 6 inches from where they are supposed to be so the male end can buckle into them.
Thanks.
Old July 19th, 2006, 04:00 PM
Hey Paul! Check this out,
http://www.defendersource.com/tech/d90seat.pdf
Will be seeing the new Defender at the Rally this year?
Old July 19th, 2006, 04:55 PM
Paul Davis's Avatar
Paul Davis
Paul Davis
97 ST
Yeah, definately see us in the 90 at the rally. Looking forward to seeing everyone again.
That is the reference I am using and all is well up until I try to put the female ends with the male ends. It is like I am 6 inches short, no comments please! It just doesn't make any sense.
Old July 19th, 2006, 05:18 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Hey Paul
Don't worry no comments other than you can have a look at this thread. There are some pictures of my setup, but its in a SW. Good Luck.
DJ
Old July 20th, 2006, 10:01 AM
Paul Davis's Avatar
Paul Davis
Paul Davis
97 ST
Thanks for the pictures on the link. How long is the seat belt on the buckle side?
installation
Rear Bench Seat + hardware Chaucer For Sale - Parts 8 September 29th, 2005 12:16 AM
rear roll cage, rear seat, soft top surfd90 Wanted 0 January 12th, 2005 02:59 PM
Side Brackets for Rear Bench Seat & Rear Seat Belts zed111 Wanted 2 August 16th, 2004 12:33 PM
Wanted: Forward facing rear bench seat zed111 Wanted 0 July 26th, 2004 01:52 PM
