Need some Brake schoolin' - Defender Source
Old October 17th, 2012, 11:27 AM
Well trying to sort out the brake thing has my head swimmin! I have a set of rear calipers from my RRC that I find do not fit the caliper adapter brackets I bought for the Salisbury. The mounting bolt holes on them are too small. So I guess I need some 110 rear calipers. I am unsure which ones to get as there seem to be several flavors and of those not sure which ones fit the adapters and rotors I have or whether I need different rotors to match the calipers. On top of that I am unclear on the rear pads.
Old October 17th, 2012, 11:46 AM
Holes on the calipers or on the brackets are too small?
What year are those RRC calipers off?
As I understand at some point there was a switch to metric on the caliper mounting bolts.
To my knowledge, there is only one rear rotor size/shape (some have provisions for ABS rings, some don't) and the pads you get to match the calipers.
Old October 17th, 2012, 12:35 PM
Holes on the calipers or on the brackets are too small? Calipers
What year are those RRC calipers off? 93
Old October 17th, 2012, 12:54 PM
Well not on these calipers. The difference is about 3 mm. Guess I gotta keep digging
Old October 17th, 2012, 01:06 PM
That is bizarre.
brake
Series I II IIa III Heystee disc brake conversion kit kullberg Series Technical Discussions 8 June 14th, 2012 03:42 PM
Parking Brake and Rear brake light gas-man Defender Technical Discussions 9 February 20th, 2012 11:40 AM
Emergency Brake Issues Ragland Defender Technical Discussions 10 April 7th, 2005 07:09 PM
