Need Serious Help - Defender Source
Old December 7th, 2005, 01:10 PM
insaneinthebrain
Dan Pm
Need Serious Help
Hi i am posting on behalf of my mate. he needs to take off the front vents on his land rover defender because he is an arse and it isn't in his hayes manual. help would be appreciated thank you.
Old December 7th, 2005, 01:14 PM
Which Vents are you refering? The ones under the windscreen? Or, the plastic vents on the wings?
Old December 7th, 2005, 01:22 PM
insaneinthebrain
Dan Pm
they would be the ones under the windscreen
Old December 7th, 2005, 02:07 PM
Um, take out the pins and unbolt the operating lever.
Old December 7th, 2005, 03:22 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
http://www.defendersource.com/mod/vent_seal/index.html
Old December 7th, 2005, 06:58 PM
Hoss
Jeff Sturgis
1995/D-90
Just that easy. I would only add that it is helpful to spray the operating lever hinge and nut that secures the lever to the vent with a penetrating oil (e.g. WD-40 or PB Blaster). Both my lever hinges were completely stuck, and removing the pins alone did not allow enough access to get a wrench on the nut.
Cheers!
Old December 8th, 2005, 08:17 AM
GeoParth's Avatar
GeoParth
George Parthmer
1995/d-90 #2715 yellowST
yeah - be careful. my drivers side latch broke and it was a total pain in the ass to fix. first, i had to get the entire assemply from rovers north and take apart the bulk of the dash to install it. there might have been an easier way but i recall having to use a mirror and bolt peices together in reverse b/c of working with a reflection (i am not sure that even made sense- i havent had my coffee yet!)
the moral of the story - as with everything, being methodical will save a lot of future work!
george
Old December 8th, 2005, 11:36 AM
Its much easier on a truck without a roll cage - the bar across the windshield base is hard to work around. You can do it without removing the bar, but its easier just to unbolt the 4 fasteners and remove the bar.
Serious Garage Cleaning woldd90 For Sale - Parts 23 September 23rd, 2009 02:30 PM
Staun internal beadlocks jam90 Defender Technical Discussions 5 March 4th, 2006 10:03 AM
Advice need!!! Please help!!! reaper99999 Defender Technical Discussions 10 February 9th, 2006 08:49 AM
serious leak? scubadanster Defender Technical Discussions 7 April 16th, 2005 03:09 PM
how many miles can i expect out of a d90? danpetrov Defender Technical Discussions 6 July 8th, 2004 12:54 AM
