Need pics of aircleaner mountings 200tdi - Defender Source
Old January 19th, 2012, 04:32 PM
Naplm00
Matthew
Well my aircleaner was just wedged in there previous to my motor pull. Now that im about to put the new engine in I need some examples of good ways to mount this thing. Custom is fine or stock let me see how you guys have it done.
Old January 19th, 2012, 04:52 PM
Sorry? Do you have the correct stock air cleaner and want to know how it mounts? It just squeezes in there and will be hard to figure out from pictures. I think it would be pretty hard to mess it up as it is a tight fit and not a lot of space to not get it right.
Old January 19th, 2012, 05:05 PM
Naplm00
Matthew
Yep stock aircleaner, ive seen people mount them on both sides of 200tdis, hence why im asking.
My mounts are missing but I do have some huge 9in SS band clamps i was planning to use. Mine was wedged under the left wing and against the heater hoses.
OK, here are some.
ID:	46354   Click image for larger version
ID:	46356   Click image for larger version
Old January 19th, 2012, 05:23 PM
It hangs out just to the right of the intercooler piping (when facing the truck), longitudinally, horizontally, with the cover pointing to the front of the truck.
Red90's definitely right about not having a lot of room. With the alternator, intercooler piping, turbo, intake manifold, exhaust downpipe, RHD heaterbox, wheel spats, and washer bottle, there's really only one place it can go.
Old January 19th, 2012, 08:20 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I can't speak to a 200 but the 300's have the bracket that attaches to the RH side of the motor with two rear head bolts. It has the filter exit hose that goes behind the motor around and then into the turbo. On the bottom of the air filter the inlet hose goes down and connects to a dump valve , for water, and then into the RH fender side vent. Once installed you can not see much of the hoses as they are covered by the air cleaner case. On the hose that goes behind the motor, to the turbo, is a connection for the crankcase breather hose.
Land Rover 110
Old January 19th, 2012, 08:51 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
A few pictures of my 85 200tdi hope this helps
Name:	19-jan-12 061 (800x600).jpg
ID:	46366   Click image for larger version
Name:	19-jan-12 062 (800x600).jpg
Name:	19-jan-12 063 (800x600).jpg
ID:	46368   Click image for larger version
Name:	19-jan-12 064 (800x600).jpg
Name:	19-jan-12 065 (800x600).jpg
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old January 19th, 2012, 11:10 PM
Naplm00
Matthew
Well it looks like I'm just going.g to have to rig something in the corner there. Bummer
Old January 20th, 2012, 09:56 AM
Why not just get the correct parts?
Old January 20th, 2012, 10:28 AM
Capt Milks's Avatar
Capt Milks
However you decide to do it you want to keep in mind that the colder the air the more power you will have. That is one reason the factory used the side vent on the fender, to get cooler air. You also have to be a little careful on where you are terminating the intake so that you are not picking up crud and or water.
I think one reason the factory hardware is not used in the converted engine trucks is the cost and availability of the parts. Those hoses are expensive! On one truck I made a bracket that was in the same factory location but attached by some other bolts other than the head bolts.
Name:	Air Cleaner.jpg
Land Rover 110
Old January 20th, 2012, 11:15 AM
Naplm00
Matthew
expensive and hard to find. I was just wondering by location where people were placing things, so i could relocate it more easily. Just simpler to do once you see what others have done
Old January 20th, 2012, 11:49 AM
Expensive and hard to find??? Any junkyard in the UK and a few dollars. You just need to ask around. Should all be easy and cheap. It is just so much simpler in the end having stock parts.
200tdi, mount, tdi
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
pics need of coil -please!! mattdh Defender Technical Discussions 0 April 29th, 2005 01:41 PM
Need Pics of 97s Mike Hippert Defender Technical Discussions 2 February 5th, 2005 12:56 PM
can someone take pics for me? mattdh Defender Technical Discussions 7 February 6th, 2004 12:17 PM
