need new shocks and tires-what to do - Defender Source
Old June 5th, 2008, 12:13 AM
CWF
Clint Falk
97 D90 yellow ST
I need to replace my shocks, and I cant decide which tires -either 265 BFG AT or 285 BFG AT. Should I go with the OME full suspension/lift, or go with new original style springs with bilstein or OME shocks for orig. ride height. Which Tires? Never off road. Weekend driver. Do not want to do anything that would hurt the drivability or value of the truck. Of course, I want it to look the best at the same time.
Old June 5th, 2008, 02:20 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
The 285's would look good with a nice 2" lift using RYM springs. You would not be disappointed. It would actually handle better then stock. I think that the BFG AT is a great choice for a never offroad but a truck looking tire. A set of springs and tires will not hurt the value of your truck at all..
Legend in My Own Mind.
Old June 5th, 2008, 08:02 AM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
I put the RYM 2" lift and the OME shocks on mine. And love it I would also recomend the 30mm wheel spacers. I just put them on mine. Adjust the turning radius bolts and you will not beleive how much shorter the turning radius will be. also widens the stance for a more stable and aggressive stance. I will send youa pic if you want!
Old June 5th, 2008, 08:43 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
If you never wheel it and only weekend drive it then keep it stock for the next guy.
Old June 5th, 2008, 09:05 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Lot of money to make a truck "look" like something. Get LR OEM springs from RDS and new billstein shocks from Great Basin. AT in 265.
EwS
Old June 5th, 2008, 09:48 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Dana,
Lets see the pic!
Old June 5th, 2008, 10:37 AM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
How about the 255/85 MT? IMO, the BFG MT looks better on a Defender than the AT.
Regarding the lift, has anyone tried using the spring isolators like EE shows? They claim it will give close to an inch and improve the ride. I have thought about those with HD LR springs. My thought is to go with 255's next time, and some here have mentioned it is a little tight stock.
"Uhh...I think they all leak like that."
Old June 5th, 2008, 10:51 AM
GYM's Avatar
GYM
Gary
97 SW
Originally Posted by Eric Siepmann
Lot of money to make a truck "look" like something. Get LR OEM springs from RDS and new billstein shocks from Great Basin. AT in 265. EwS
Agreed.
Old June 5th, 2008, 12:55 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
isolators do not improve the ride. they do give you a little bit of lift, but closer to 1/2 inch is my guess. i installed them on my truck, but i'd not go through with it again. imop
Old June 5th, 2008, 06:39 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
I agree pretty much. Not much lift but 1/2 inch may be possible. I didn't really notice a ride difference.
Old June 5th, 2008, 08:36 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
Get them to you fri.
Old June 6th, 2008, 10:19 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
FYI, I just purchased some Fox Shox and found a very good deal from Offroad Engineering.
http://off-roadproducts.com/2_0_pro_series_.html
I went with the 2.0 Emulsion 5/8 shaft 11" travel with 40/80 valving as recommended by Keith at Rovertracks. I thought some of you guys might be interested in the deal going on right now at Offroad Engineering.
Old June 6th, 2008, 10:39 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
40/80 valving both front and back?
Old June 6th, 2008, 10:43 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Yep!
They come 30/90 which is not much different but Keith said so and I went with his expertise.
Old June 6th, 2008, 10:47 AM
cellulararrest
Chris Snyder
Yep!
Let me know how you like that valving. I have a set of 2.0's I need to rebuild and am planning on revalving at the same time.
Old June 6th, 2008, 11:33 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
No problem.
Old June 12th, 2008, 11:47 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Chris,
I finally got both front and rear fox shocks installed. Either my OME shocks were old and worn out (I didn't notice any problems) or these Fox shocks are surprisingly better. I notice much less lean and body rotation on the road. I don't have any anti-roll bars so I noticed a fair amount of lean with the OME which has gone by the wayside with the Fox shocks. I can't wait to get these off road.
Old June 13th, 2008, 12:06 AM
cellulararrest
Chris Snyder
good to hear. Thanks for the follow up!
And just for the hell of it... What mounting setup front and back did you end up going with? It looks like there are a bunch of options.
Old June 13th, 2008, 03:00 AM
I like the bilsteins with the stock ride height springs and 265 75 R16 tires for on road.
Old June 13th, 2008, 12:44 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
For the rear I went with Upper and lower mounts from Steve at Rovertym. In the front I tried to use Steve's adjustable shock towers but since the Fox shocks mount with the shock upwards and the shaft down I couldn't get the shocks body to fit into towers at the upper end. I had to go with the DII shock towers for the front and Rovertym lower mounts. I also added a 1" block under both front and rear springs. I really like the setup so far. But things always seem to change as my wheelin characteristics change. This setup should last a few years, however.
Your right about there being a bunch of options. I have been contemplating this task for about a year (since the Solihull Rally in Montrose). I finally just called keith at Rovertracks and went with his suggestions. Great guy for sure. Thanks Keith.
tire, tires
Tires and Safari Gard shocks jperakis For Sale - Parts 4 May 2nd, 2008 10:00 PM
shocks and springs (again) rover4x4 Misc. Chit-Chat 21 October 8th, 2006 06:04 PM
1997 NAS D90ST, BRG: New block, top, tires = $35k jhopp For Sale - Vehicles 2 August 4th, 2006 11:20 AM
Free tires Trigger For Sale - Parts 9 May 18th, 2004 07:23 PM
OME suspension, and tires huntahdefender Defender Technical Discussions 4 October 10th, 2003 04:14 PM
