need new radiator 110 Tith 2.5na - Defender Source
Old August 31st, 2016, 08:03 PM
buck toenges
fred toenges
1986 110 tithonus
Can you guys give me advise on getting a new radiator? oem? aftermarket? something else?
My oem is leaking. I am using this truck as a winter driver. Nothing crazy just going through mild snow. Can you give me an idea if a radiator cover is a good add on for winter driving?
Buck
Old August 31st, 2016, 08:06 PM
Choices: Recoring or replacement. I bet Recoring will work.
Old September 1st, 2016, 02:37 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
I passed my old one along to Adam (speedpin). Not sure where it ended up but he may chime in on a good deal for a used one. It came out of a Tith. IIRC, it wasn't in bad shape.
-Neil
Old September 2nd, 2016, 07:09 AM
Parrie's Avatar
Parrie
Parrie Willette
1989 D90 P/U
Buck
Considering the cost of a new OEM radiator I'd first consider re-coring. How bad is it leaking?
A radiator cover will certainly help hold the heat in the coolant which should translate into better heating inside the cab if that's what your after.
Old September 2nd, 2016, 07:21 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I have a used one that didn't leak. I can get you some pics later if interested.
Old September 2nd, 2016, 07:28 AM
wanabewheelin's Avatar
wanabewheelin
Michael Sword
1989 110 200TDI, RHD
I have one out of my 89 110 ... 2.5TD, not sure of the difference between the TD and NA here.
Put it on new in Oct of 2014 and used it until we pulled the 2.5TD in Feb of 2016.
Let me know if you are interested and we can discuss a price . . . taking up room in the garage.
Old September 2nd, 2016, 07:31 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
I have 1 or 2 if Michael's falls through.
RDavisinVA
Old September 2nd, 2016, 12:30 PM
Greg S
Greg Sutfin
1986 90
If it's leaking, get it fixed! It doesn't mean you need a new one. Do you buy a new tire just because you get a flat? Go to a radiator repair shop, not an automotive repair shop. If it is bad enough to need replacement they'll tell you.
Yes! A radiator muff helps!
Old September 2nd, 2016, 12:49 PM
Do not buy a new one. Going to a good radiator shop and having it repaired or recored will result in a better radiator than any of the new options.
110, radiator
Suspension for my '87 Tith 110 Tribe Defender Technical Discussions 14 November 20th, 2015 09:47 AM
Wanted: Soft Top for 110 Tith, and LHD Power Steering Sam1 Wanted 6 November 8th, 2015 02:56 PM
Leveling a MOD/Tith 110 speedpin Defender Technical Discussions 15 November 4th, 2015 06:17 AM
Fuel line clogging 110 Tith Tribe Defender Technical Discussions 23 September 19th, 2015 06:24 PM
2.5NA for sale with radiator, new alt and timing kit ontheway For Sale - Parts 5 December 3rd, 2014 11:10 AM
