Need new drag link & pitman arm !? - Defender Source
Old March 23rd, 2006, 02:43 PM
Rover- Girl
Guest
Posts: n/a
Arrow Need new drag link & pitman arm !?
OK, so after I finally have the tire issue out of the way ( had the steering stop moved ).
I was told that the pitman arm and drag link would probably have to be replaced in the near future.
They are not bend or warped, but have a lot of weather rotting / dry rotting going on and a lot of movement!?
Is there a way to just replace the bushings ( seals, rubber parts ) or do I have to get a new arm and link !?
If I have to replace this, are there any upgrade options !?( mide as well go all out, right )
Thanks, again for everyone's help.. Christine
Old March 23rd, 2006, 03:44 PM
hey Christine, You can always upgrade! But you can bye all the parts you need to rebuild them from DAP, although you need a press to rebuild some of the parts, or any good shop can do the work.
As far as upgrade, you can upgrade the drag link with a heavy duty unit that is less likely to bend if it gets hit. the draw back, heavy duty stuff will only bend back with a 20 ton press, while a stock bar can be removed and bent nearly straight on the trail. I doubt that the drag link bar itself is rotted, but the bushings most likely are. It would be a good idea to replace the pan-hard rod bushings, both ends on the drag link and the tie rod ends all at the same time. I think DAP sells a kit to do most of that.
Old March 23rd, 2006, 04:41 PM
Rover- Girl
Guest
Posts: n/a
Ditto , thanks mike...
Just got off the phone with DAP and ordered all the parts needed....
guess I jumped the gun, however, I would like to get some belly protection..
Any insight on that subject would be grant
Thanks....Christine
Old March 23rd, 2006, 04:48 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Take a look below in the Similar Threads results box, a few topics already are listed that might be helpful.
Chris von C
[/size]
Old March 23rd, 2006, 06:33 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Mine needs the same thing, the tie rod ends and drop arm joint need to be rebuilt. I plan on doing mine when it warms up a bit more. If you do it yourself, or get a shop to do it, either way it's a good idea to have a front end alignment at the same time.
-Hans
My oil line fix
My 100k stopped odometer fix
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
Pitman arm to Steering box question dmarchand Defender Technical Discussions 3 September 5th, 2008 11:53 PM
Drag link end @ steering drop arm Uncle Douglas Wanted 3 August 10th, 2008 11:14 PM
Pitman arm Picture Buckon37s Defender Technical Discussions 7 March 4th, 2006 06:02 PM
little piece that steering damper mounts to near pitman arm evilfij Wanted 4 October 5th, 2004 08:55 PM
