Need measurements for SW side window placement - Defender Source
Old May 28th, 2009, 01:24 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Hello,
I am going to be adding side windows to my van side and need the following measurements to make sure I get the windows centered properly.
Rear of hardtop to edge of window
Front of hardtop to the edge of window
Bottom edge of hard top to edge of window
Top edge of hard top to edge of window
If possible I would like to get measurements from a couple of 90ís just to make sure I get it in the proper place.
Thanks!
Name:	side window.jpg
Old May 28th, 2009, 01:47 AM
I measured off JimC's truck. 1.5in top and bottom and 6in short side and 7.5in long side IIRC (I can't find the piece of paper I wrote it down on). I am cheating because I bought randy's spare window side as a template. I am going to drill out the rivets and measure the hole from the sliding one to install the fixed glass in both sides off of a fiberglass top.
Old May 28th, 2009, 02:49 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Here ya go.
When i did mine, i put a nice thick strip of masking tape all around the general area where I was going to cut, then marked it out with a pen (you can draw onto the masking tape easier than the bodywork) and then when you run the jigsaw around to cut the hole, you don't end up scratching the paint either side of the cut (OK, it doesn't matter inside the cut, but the outer edge could show up past the window rim)
Name:	90 side window dimensions.jpg
Old May 28th, 2009, 09:08 AM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Dave -
Edge of window to bottom of rain gutter (rubber strip between to components) = 1.455 in.
Edge of window to top of tub = 1.480 in.
Edge of window to rear = 5.850 in.
Edge of window to front = 7.460 in.
I can drive the 90 over so you can get eyes if you want. Mark
Old May 28th, 2009, 09:09 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Jamie,
Is the side window you installed a stock factory item or aftermarket?
Ron,
Do you have the side at your house? If so can you measure it for me?
Mark what days / hours are you around? I am in Denver today and will leave Friday night to go back to Fort Collins. I could drive to your place if you are going to be around.
Old May 28th, 2009, 09:28 AM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Working today till about 4:00pm. I could drive over tonight or you can swing by. What ever is convenient. Mark
Old May 28th, 2009, 11:32 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Originally Posted by dave_lucas
Jamie,
That picture (and measurements) was taken off of a brand spanky new d90 on the dealer forecourt.
.....so expect it to be incorrectly fitted!
Old May 29th, 2009, 10:03 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Mark,
Sorry I could not make it, things were super busy at work If you get a free moment could you measure your top for me so I will have 2 point of refrence?
Thanks Jamie, I just wanted to make sure it was not an after market unit as they are a little diffrent
Old May 29th, 2009, 10:58 AM
Hey Dave - Let me pull Ron's out of the garage and measure it - the window is out, so the measurement will be more precise.
Old May 29th, 2009, 11:11 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I am going to try and get them cut / installed this weekend so it will be nice to have solid data points
Old May 29th, 2009, 11:57 AM
"the window is out, so the measurement will be more precise."
Really? Did it come with a window?
Old May 29th, 2009, 12:02 PM
Yeah, window was just not installed.
Old May 29th, 2009, 12:07 PM
Sweet, saves me drilling out the rivets.
Ron
Old May 29th, 2009, 10:00 PM
Here are two sides, the size of the hole is of course dependent on which window you are installing. I was distracted by a two-year-old during this process and couldn't complete the job.
Oh, its hard to see. This is a RH side. Right side of the pic is the front.
Name:	Window Measurements.jpg
Old May 29th, 2009, 11:07 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I am installing fixed windows from a fiberglass top.
I thought the fixed windows in the fiberglass top and the sliders in the SW were the same size
So the area that says 205mm is the RH front and the area that says 50mm is the bottom correct?
Old May 30th, 2009, 07:15 AM
Yes, according to what I've seen, these windows are the same size. From talking to LenB, he verified this when he installed solid fiberglass top windows in his side panels.
And yeah, you got the dimensions right. They look consistent with the measurements from others, allowing for the width of the window frame.
Old May 30th, 2009, 12:24 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Dave-
I'm in Denver with a fiberglass top in pieces if you wanted to borrow the sides to make a template. Let me know.
Alex
Old May 30th, 2009, 05:14 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Are the windows out of the fiberglass top?
I will be in Denver M - F afternoon of this week.
ac, window
Passenger side sliding rear window for a 90 or 110 roofside and one fixed window evilfij For Sale - Parts 2 June 2nd, 2009 10:46 AM
Side Window Guards Zeke Wanted 8 February 3rd, 2005 08:49 PM
D90 SW side window trim wanted Chris Cox Wanted 0 January 26th, 2005 05:09 PM
Plastic parts from driver side window?? Vadim Defender Technical Discussions 1 January 18th, 2005 03:06 AM
Soft Top Side Window Bar boshea Wanted 2 June 18th, 2004 08:14 PM
