Need Help with Springs for an 88 Coil Truck - Defender Source
Old May 31st, 2006, 07:31 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I am looking to get a set of stock springs from RDS for my Coil sprung 88 project. George says ther are several different color springs. How do I know which combination I will need? Any Help would be great.
RAndy
Legend in My Own Mind.
Old May 31st, 2006, 07:53 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
The colors relate to different part numbers, you can use a parts book to get the part numbers and then that will tell you the colors. Depending on what your set up is you'll need to mix and match. In a coil 88 keep the spring height pretty short as the rear driveshaft length is always and issue with the short wheelbase.
Email:
Old May 31st, 2006, 07:56 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Mike, I PMed you. What color\part # do you recommend for my setup? Also, should I run matched springs in the back and in the front or should they be sided?
Old May 31st, 2006, 08:09 AM
ECR's Avatar
ECR
Sorry, the way my books (and my head) work. I can tell you the color once I have the part #, but I don't know all the colors off the top of my head. I have a a lot of Rover part #s memorized, but not the color codes, sorry. I can look it up and get you part #s if you give me a few days.
My suggestion would be just get 4 crappy used springs and mock it up on those, then adjsut for height with new springs as needed once all the weight is on.
Email:
Old May 31st, 2006, 01:33 PM
You will want fairly light springs. For my 80in coil project I have some RRC fronts in front and probably D1 fronts in back as it looks like it will be scary high with RRC stock rears.
Old May 31st, 2006, 02:44 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I just ordered a set of stock d-90 springs from RDS...... I will see how it sets up.. I got the colors and part #'s from my parts book actually.
Old May 31st, 2006, 03:02 PM
Depending on engine and other weight factors, they will give a fair amount of lift to an otherwise stock 88. Once you figure out what is all going on there you might want to consider RRC rears for the back. They are lighter than D90 as the RRC has the BOGE unit. Not sure exactly how your designa frame works but on my 109 designa the mounts are a bit lower than a defender so it might actually work ok. On the 80in it is going to be really light and with the stock driveshft lengths will be difficult to use even stock springs. I may even have to go to DII fronts (inch shorter than DI) in front.
Old June 1st, 2006, 07:15 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Ron, you really think a 90 is that much heavier then an 88. I would think that the 90 springs will be a nice setup. The rear spring perches look a little higher then on the 90 frame from what I can see..
Old June 6th, 2006, 09:40 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Randy,
My 88 coiler weighs 3750 lbs as per the transfer station scales. With Hard top, lift tailgate, and a 2.25.
Old June 6th, 2006, 11:28 AM
My 90 weighs ~3600 my series IIa weighed 2980 on the scale.
Old June 6th, 2006, 04:38 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Randy,
You will want a Tom Woods drive shaft as well since the series shafts slip splines are too short for a coilers suspension.
Old June 6th, 2006, 06:55 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Yeah. I will have to see with the back. I might even need a CV shaft. Have to check room first..
coil
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
Expedition Exchange shawnpalmer Misc. Chit-Chat 155 June 4th, 2007 10:56 AM
brake pad anti rattle coil type springs. thewap Defender Technical Discussions 2 August 20th, 2006 09:56 AM
D90 Springs... arbik Wanted 2 March 25th, 2006 10:09 AM
LR HD springs sets TDI Guy Misc. Chit-Chat 11 February 3rd, 2006 09:22 PM
» Defender Registry
NAS D90
Sned
OffRovr
speedpin
Add your Defender
