Need help with some dimensions.... - Defender Source
Old April 27th, 2004, 06:02 PM
tbmcneill
Guest
Posts: n/a
If someone's got a few minutes, I was wondering if you could go out and take a few measurements off your hood.
Specifically I need the following:
1. overall width at the firewall
2. overall width at the nose
3. height at the firewall
4. height at the nose (just before where the hood 'rolls' down to meet the grill)
5. distance between mounting points (center to center)
6. overall length
Thanks for the help-
T
Old April 27th, 2004, 08:58 PM
mattdh's Avatar
mattdh
Matt Hurst
1. 56 in 2. about 33 in 3. 4 5/8 in 4.about 3 in 5. 36 5/8 in 6. 45 3/4 in
Old April 27th, 2004, 11:04 PM
tbmcneill
Guest
Posts: n/a
Matt,
Thanks a million. You just saved me a bunch of headaches and time. I owe you one....
T
Old April 27th, 2004, 11:09 PM
mattdh's Avatar
mattdh
Matt Hurst
troy -could you help with the wirring of the ignition swith by any chance?we could call it even then
Old April 27th, 2004, 11:12 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Do I smell a buggy
World traveler
Old April 28th, 2004, 12:52 AM
tbmcneill
Guest
Posts: n/a
matt-
I may be able to... I've wired 2, but its been a couple of years ago. I'll see if I kept my notes. I'll PM you.
.... & as for you, Ninja Boy ....I'm just goof'n off.
T
Old April 28th, 2004, 01:34 AM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
You better watch it with that Ninja stuff, I just became an on duty one
World traveler
Old April 28th, 2004, 08:23 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Yousef, just when you think people forgot about it, someone brings up the Ninja word again..... lol
Legend in My Own Mind.
Old April 28th, 2004, 02:11 PM
tbmcneill
Guest
Posts: n/a
matt-
I couldn't find the notes I wrote down, but here's the lucas wiring code I used to figure it out.... Lucas Wiring Color Codes
I also pulled apart the back plate of the switch so I could see what part of the switch contacted which contacts as the key was turned.
Between the wiring code and that, I was able to figure out which wire went where.
Sorry, I don't have the 'quick fix' .... maybe someone who has their dash apart could give you the actual order.
T
PS----
LOL... you know I got nothing but love for you brother
Old May 4th, 2004, 02:34 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I have my dash apart still I can take a pic if you like! I have a 110 but should be the same I also have a manual I can see what that says as well. Send me an email & I will forward.
Old May 4th, 2004, 10:13 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Peter, snap some pics, I have to put mine back together and I lost all my pics too.
Old May 4th, 2004, 02:47 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Here you go the pic is taken for the pass side looking tword the drivers side.
Peter
Old May 4th, 2004, 03:01 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
MY pic's won't load!
Old May 4th, 2004, 03:23 PM
mattdh's Avatar
mattdh
Matt Hurst
here is peters pic. thanks peter
Old May 4th, 2004, 03:26 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
How u do that!!!!!!!!!!!!!!
Old May 4th, 2004, 03:36 PM
mattdh's Avatar
mattdh
Matt Hurst
peter- i click on browse next to attach file,then my file upload pops up an d i find the pic and click on the pic and then click open -that should be it. as far as the wiring-could you fill back behind the ignition switch and tell if there is an extra prong.the white wires with red and orange stripes are close to you and behind those two is a white wire and a brown wire with the white being plug in above the brown wire,could you tell me which prong is not used(the top, middle, or bottom)thanks again
Old May 4th, 2004, 04:03 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I just took a look AND I do have 5 & the top & bottom on the left side are used the middle is "omitted" brown bottom & top is white.
right side red & white bottom orange & White are top!
I did what you described and my pics still won't load!?!?!????
I hope this helps!
Peter
Old May 4th, 2004, 04:09 PM
mattdh's Avatar
mattdh
Matt Hurst
peter does the file name show in the attach file box after you click open
Old May 4th, 2004, 04:14 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
YES! Maybe I was not giving sufficiant time to upload?
D110 Internal Dimensions johnnyrover Misc. Chit-Chat 5 January 31st, 2006 11:43 AM
Soft top Dimensions Clarson1359 Defender Technical Discussions 0 February 22nd, 2005 08:01 PM
Anyone know the dimensions? ripp2002 Defender Technical Discussions 2 February 2nd, 2005 01:50 PM
Interior dimensions of ST D-90 Eric_S Defender Technical Discussions 5 August 26th, 2004 01:49 PM
'95 NAS D90's vehicle dimensions NJ-D90 Defender Technical Discussions 1 June 2nd, 2004 08:01 AM
