Need help with D90 engine problem - Defender Source
Old January 9th, 2004, 03:07 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
Question Need help with D90 engine problem
I need help with an engine problem I am having on my 97 SW. I picked it up today from the body shop, where it has been for 5 weeks. I checked the oil and let it run and get warmed up good before driving. On the way home, the oil pressure light came on, and the truck started running like crap. It lost power, like it was running on about 4 cylinders. I limped to a gas station to check the oil again, which was fine. After a few minutes, I cranked the truck, and everything was fine. This is really starting to bug me, as this has happened a few times before, but the oil pressure light never came on. I realize that I will need an engine in the near future, as the one I am running has 190,000 miles on it, but I don't want to pull the one I have until absolutely necessary, since my project 90 has pretty much depleted the rover fund. Thanks for any help.
Old January 9th, 2004, 03:57 PM
Could be the ECU. Do you have another ECU that you could swap in? The oil pressure light will also come on if the RPMs drop real low ( 200 to 300 RPM).
Old January 9th, 2004, 06:11 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
Mike, I don't have a spare ECU. I do know that the truck had a coil-pack replaced under warranty, only after about 5 attempts at diagnosing a rough running engine.
Old January 10th, 2004, 08:41 PM
Did the ECU throw any codes? If it was running that bad I think if the ECU was working correctly it would show a code to piont you the right direction.
90, d90, engine
'97 D90 engine electronics and "Y" pipe troutrover For Sale - Parts 11 March 7th, 2012 11:25 PM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
4.0 used, complete engine dmarchand For Sale - Parts 0 September 28th, 2004 03:12 PM
D90 Engine Overhaul Landyfun1 Defender Technical Discussions 19 April 20th, 2004 06:02 PM
