Need help with check engine light - Defender Source
Old September 12th, 2006, 10:06 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
Hello there, Another newbie to the site,
OK here goes, I have a on going problem with this little yellow light on the dash. I keep trying to get it to go away and it persists on sticking around. I have code reader and the code is PO420 something about catalst effientcey, I went to a local guy here that does work on rover an asked him about some of the issues. I thought it was the cats or O2s, He did not think so he thought it was a leaking injector. I check the cats with a laser temp. senor. Both cats read around 420 deg. at the front of the cats and around 510 at the exit. It is a 97 with 47,000 miles on it. You don't think the cats would be bad already do you? replaced 2 O2 senors about a year ago. all yeah the light will stay on for days at a time then go out for a day then back on. Somedays runs really strong other days could not pass a Yugo Any ideas?
Old September 14th, 2006, 08:29 AM
BarryO
Barry O'Mahony
97 D-90 SW LE
Which O2 sensors did you replace? Your truck has four.
Old September 14th, 2006, 11:51 AM
roverboy's Avatar
roverboy
Thomas
Booger
My check engine light was on in my '94 D-90 for years. Land Rover Cape Fear in Wilmington, NC could never diagnose the problem, so they suggested that I disconnect the wire to the warning light.
True story.
Of course they would have also charged me $129 to snip the wire I'm sure...
"There is absolutely no excuse for the way I'm about to act."
Old September 14th, 2006, 12:47 PM
btate
Bryan Tate
d90
easy bitterman!
Tom,
They have a great defender mechanic now (at CFLR). It wasn't cheap, but at least my truck is running perfectly now. He was nice enough to suggest a used MAF over a new one to get the truck going. Even gave me a break on a few hours of time.....
He used to track race cars and seems to know alot about electronics/ignition/diagnostics...
I hear you are outy for the MAR?? Hate that I won't see you there.
BT
check engine light, engine, ht
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
check engine light. FREEDOM Defender Technical Discussions 14 May 31st, 2005 01:10 PM
97 D90 check engine light - on now off? Eric_S Defender Technical Discussions 3 January 28th, 2005 10:17 AM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
