Need help with 300tdi crankshaft - Defender Source
Old April 27th, 2015, 02:55 PM
piper109
Steve
1999 Disco 1 SD w/300tdi
I have a 99 model Disco 1 that I swapped a 96 300tdi and R380 into about 5 years ago. Its been running well but 2 days ago, after a short drive I restarted at home and the oil light stayed on. I shut off and tried again about 3 times. Oil light stayed on solid each time. I removed the pressure switch and bumped the engine while switch was out and no oil came out of the pressure switch hole. I removed the filter (which was full of oil) and with the fuel solenoid disconnected, I spun the engine with the starter and no oil came out of the oil filter place. Oil pan is full with Rotella T6 that I changed about 3k miles ago. Oil light has always gone out instantly until now.
I dropped the oil pan and checked the pick-up tube and strainer, all good, no blockage. Unscrewed the pressure relief and removed the parts, all free and in good condition.
I figure the oil pump is not turning as I don't know what else it could be.
I am now trying to loosen the crankshaft pullet bolt and having a big problem.
Before installing the engine 5 yrs ago, I replaced the timing belt and idlers etc and I tightened up the crankshaft pulley bolt on the ground, with flywheel locked with a flat bar linking a flywheel bolt and the bell housing. I used a breaker bar and tube and a 1/2' drive 1 1/16" socket. Perhaps I over did it but engine has run great for 5 years and 25 k miles.
Now I need to loosen that bolt and have trouble. Used the breaker bar against frame and starter routine. Nothing doing. I destroyed a 1/2" breaker bar and just got whacks from another. I need a good way to lock the crankshaft. Does anyone have a suitable tool I could borrow or rent please? or perhaps know where I could get one this side of UK. Located in NC mountains near Boone. Thanks, Steve
Old April 27th, 2015, 03:00 PM
3/4" impact. Should be able rent or borrow one.
Old April 27th, 2015, 03:01 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You need the $99 Crank pulley locking tool.
We have them for sale.
You may as well buy one if you're going to continue to run a 300TDI.
I use ours all the time.
Years ago no one had them, so I took a picture of one I saw in a service bulletin and had some manufactured.
PM if interested.
ID:	119327   Click image for larger version
RDavisinVA
Old April 27th, 2015, 04:26 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
I use a 1 inch breaker bar and socket (it was free) thanks to my last job. But the trick is to let it swing a few inches on (using) the starter before hitting the frame.
Another good point in favour of the 2hundy
Five years on a belt? Time for a change.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old May 2nd, 2015, 08:04 AM
piper109
Steve
Thankfully I was able to remove the crankshaft bolt with the tool from Rdavisinva. It was a bear none the less and I bent my new chrome vanadium breaker bar and a couple of cheater tubes before it turned loose. As it was me who tightened it when I replaced the belt (engine on the ground) I have nobody to blame but myself ! Now i have to remove the pulley and timing case etc including the inner section so I can get to the oil pump to inspect it.
Old May 2nd, 2015, 09:00 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Let us know what you find!
RDavisinVA
Old May 2nd, 2015, 06:33 PM
piper109
Steve
Oil pump is now dismantled, timing case is off. Oil pump rotors seem in good condition and very little play. The timing case recess for the pump seems a little loose however, about .008". Engagement with crankshaft seems OK too, with about 40 thousandths "rattle" movement on the flats. Certainly pump was turning. Minimal wear marks on the pump plate though the 7 screws seemed looser than expected.
The oil pressure relief valve spring should be 68mm long. This one is 46mm long (has it really shrunk 22mm??) but I found nothing that might make it jam open. A little shiny wear in a couple of places on the plunger
I am still puzzled by the apparent lack of oil circulating. Oil might have been a little hotter than usual as I had been making IP adjustments.
Any 300tdi gurus have any comments?
Steve
Old June 14th, 2015, 08:12 AM
piper109
Steve
My 300tdi is all back together and running well. Quite a lot of work. New oil pump rotors and oil pressure relief spring plus new timing belt.
I get 50 psi at idle when cold, 15 psi when hot. 30-35 psi at cruising speeds when hot.
Steve
300tdi, crankshaft, tdi
300tdi bare block,crankshaft and oil pan wanted. J. Pound Wanted 5 December 26th, 2014 08:09 PM
300tdi crankshaft gear D90user Defender Technical Discussions 0 October 19th, 2010 01:07 AM
Crankshaft Pilot Bearing Question Heath Defender Technical Discussions 15 October 13th, 2009 03:57 PM
Crankshaft Pulley bolt removal kellymoe Defender Technical Discussions 16 November 1st, 2006 03:29 PM
Crankshaft Pulley/dampner Davis Wanted 2 June 28th, 2005 12:12 AM
